EM TuningMonster Motorsport
Results 1 to 12 of 12
Thread: spacers?
    Jun 2009
    42
    spacers?
    Would fitting wheel spacers put more strain on wheel bearings? If so is it a concerning amount?
    Sonnyjim.
    stoakseya4's Avatar
    Aug 2005
    Kent, UK
    1,227
    Often discussed.
    Audi (over) engineering will have a degree of safety built in with them, and I've never heard of any faults as a result of the spacers being used.
    Possibly if the bearings were already on their way out... Maybe...
    1998 S4 Widebody Saloon Track Car
    2006 320d SE Touring - Ze Fuhrer's Wagon
    2001 B5 RS4 510bhp & 508ft lbs SOLD
    1.9TDI (130) Sport -Black-Revo - Mrs Stoakseya4's mota - SOLD
    Feb 2009
    Aberdeen
    34
    If you use hub-centric spacers then it wont be a problem as both the wheel and the spacer will locate to the hub assembly, but if you use universal flat spacers you could get some movement which could result in problems.
    I've got 15mm hub-centric spacers on my one and its perfect.
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    I had 15mm hubcentrics on my old Mk3 Golf... they were fine.... I tihnk you'll only be strainign things if you start screwing massively with the geometry: 30mm+ probably best avoided.... but you'll be able to see if you're pushign the bounds of what is "right".... also depends on what you're doing with the car!
    LostBok/BahnStormer77
    May 2009
    214
    Im pretty sure that you can use normal spacers upto 10mm and you need hubcentric if you go any bigger then 10mm
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Personally i would go any more than 5mm without hubcentrics
    i used 10mm H+Rs with hubcentrics absolutely spot on
    dont forget the longer studs
    BahnStormer
    Feb 2009
    Surrey
    2,582
    and don't go too long on the studs!!!!! (ABS sensors, hundreds of pounds, etc, etc!!!)
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Quote Originally Posted by lostbok View Post
    Sorry should have said that you should only lengthen them the width of the spacer ,
    then again you should only do this with any car even if theres no abs stuff you will still put the threads the otherside of the hubs internally and if they get rust or contamination on them you are pulling it back through the threads in the hubs when removing the studs which can be fatal for the threads in some cases .
    stoakseya4's Avatar
    Aug 2005
    Kent, UK
    1,227
    Anyone have any hubcentrics for sale, PM me.
    I'm after a pair of 15mm ideally, but will also take 10mm's...
    Ta.
    BahnStormer
    Feb 2009
    Surrey
    2,582
    not many 10mm hubcentrics... 15mm most likely... 12mm are out there... I got the 15mm H&R Trak+'s for my Golf.... expensive but fantastically engineered and very, very light... all four weighed nearly the same as ONE of the 8mm ones I was given for free!
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    I had a set of 10mm H+R hubcentrics on my S4 but i think there the only company do them in hubcentric
    nice quality as well .
    V6 Quatt's Avatar
    Feb 2008
    776
    I have some H&R
    Quote Originally Posted by stoakseya4 View Post
    Ta.
    Torque the Torque
