Hi
i changed one about 3 months ago its not too bad once you get started i was also fitting new and there are some bits on the side parts that are riveted so you will need some bits
if your not looking todo it in one hit you can get the bits you need from the stealers mid job otherwise you will have to get a fax off them with the exploded view to work out the accesories needed
you have to take the visors etc off to remove the plastic panel above the windscreen as theres a fixing nut under it , also door rubbers where rivets are / pillar trims etc
its all quite easy once you get stuck in there was nothing to difficult the worst thing i remeber was putting the door rubber back in the groove at the pillar
sorry i couldnt be more help i just got stuck into it
Paul
