my friends A4 1.8t (b6) is having a few probs. It has cut out on him a couple of times and the EPC light is on.
I ran the codes and got the following:
Tuesday,21,July,2009,17:29:10:31547
VCDS Version: Release 805.4
Address 01: Engine
Control Module Part Number: 8E0 906 018 B
Component and/or Version: 1.8L R4/5VT 0004
Software Coding: 11501
Work Shop Code: WSC 63351
Additional Info: WAUZZZ8EZ1A054559 AUZ6Z0A0082978
7 Faults Found:
17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
P1290 - 35-10 - - - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-10 - - - Intermittent
17947 - Clutch Pedal Switch (F36): Implausible Signal
P1539 - 35-00 - -
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-00 - -
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-10 - - - Intermittent
16395 - Bank 1: Camshaft A (Intake): ****** Setpoint not Reached (Over-Advanced)
P0011 - 35-10 - - - Intermittent
17658 - Fuel Level too Low
P1250 - 35-00 - -
I unplugged the MAF and the car ran fine - would you say that this is all pointing to the MAF being on its way out?
any help is much appreciated!
ta
Andy Mac
Address 01: Engine
7 Faults Found:
P1539 - 35-00 - -
P0322 - 35-00 - -
P1250 - 35-00 - -
ta
Andy Mac
