Badger5Sky Insurance
Results 1 to 8 of 8
    jcp
    Feb 2006
    Wales, UK
    10
    Rattle/ tapping noise when idle.
    Hi, I have a loud rattle/ tapping noise when the engine is idle - any ideas what this could be?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Need a bit more info.
    Diesel or petrol?
    What kind of tapping?
    Where in the engine is it coming from?
    Is it engine speed dependant?
    Does it do it all the time?
    etc etc
    jcp
    Feb 2006
    Wales, UK
    10
    It's a petrol 1.8T. The sound seems to be coming from towards the back of the engine.
    The tapping is not always there - and seems to go away when the revs raise above 1000 rpm.
    Thanks in advance.
    jcp
    Feb 2006
    Wales, UK
    10
    Just a quick update - audi have suggested that it could be the cam chain tensioner, however they are not sure why the noise is only there on start-up and when the engine has reached 90c.
    Any ideas.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,506
    It is common for the cam chain tensioner to give problems. It is exasperated when warm due to lower oil pressure and thin oil, and at start up due to the oil having drained away from the tensioner itself.
    You may also find that your oil pressure itself is a bit on the low side due to partial sludging/blocked strainer.
    How often do you change the oil, and using what type of oil, also has it ever been flushed fully?
    jcp
    Feb 2006
    Wales, UK
    10
    The oil is changed every 20k by audi 5/30 I guess. Do you suggest that I flush the engine before getting the tensioner changed. If so what the best way to do it?
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Have you had your CAT checked????
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    Quote Originally Posted by jcp View Post
    I'm not a fan of 20,000 mile oil changes.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
