Power loss, poss boost problem?
hodgy0_2
NULL
Hi guys
first post so bare with me!
I have a 2.5TDI quattro (see pics)
in the main, very pleased with it
but it seems to really lose all power, only sometimes though, at first i just though i was catching it "off boost", or some sort of niggle with the tiptronic system -- but its not that, its almost like the turbo suddenly vents to air, with my foot flat on the floor, nothing (the rev needle sits at 3k) as I let my foot off, the urge comes back
other than that it drives superbly -- any ideas
thnks - hodgy
I'd get it checked on Vag-com for any error codes, sounds like a stuck egr valve. All error codes are stored, so befriend someone on here with vag-com.
:sign_welcome:
I agree with arthur, get the codes scanned, similar symptoms on mine pointed to the MAF.
cool thanks guys
so next question is - does anyone know a Vagcom guy in the Cambridge area, maybe a mobile guy
and what does the "check" button do on the dashboard, will that not show the codes
Check button will not show codes. Someone should be able to help you or else you can buy a lead from ebay for £15 and download a shareware version of the software to read codes..
have you link to the shareware version, and is the lead a standard ODB11 one
do halfrauds do these leads?
ok apologies I,ve got the shareware
but in the meantime took it to my local garage who put it on a "vagcom" type thingy
the codes are 00542 shock sensor nozzle needle g-80 -----
00575 Manifold absolute pressure control limit exceeded - intermittent
01375 Engine mounting valve step -----
17978 - Engine ECU Blocked P1570
all the codes cleared apart the first one
I am thinking that the 00575 one could mean its overboosting, hence the feeling of no boost as it just shuts the turbo off
any thoughts
35
2K
6
679
6
685
996
