AH FabricationsChris Nott
    Jan 2006
    UK, Blackpool
    100
    19" Tyre pressures!
    Hi
    Just had some 19" RS4 alloys and 235/35/19 tyres fitted to my A4 3.0 Cab...
    The fitters said the tyre pressure they use was 30psi, which I thought was a bit low, especially as it squirmed and squeaked its way around the forecourt once fitted.
    If I thought it was too low then they suggested I up it....so I added another 5 psi.
    It seems a lot better but I'm still not sure as it sometimes 'digs' in on corners and I was wandering if I should up the pressures another 5psi to 40psi?
    Anybody else got experience with 19 inchers and what pressures work for you?
    Andy
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    I find 34psi all round does it for me!
    wallacr's Avatar
    Nov 2003
    241
    I run mine at 32psi and that works well for me
    dans3.0's Avatar
    Apr 2007
    53
    Roll with 41 front and back as per tyre sticker on my 3.0 cab with 18 inch wheels.
    Dan
    A4 CABRIOLET 3.0 SPORT MULTITRONIC loaded
