EM TuningMonster Motorsport
Results 1 to 14 of 14
    30
    Rs4 reps 18' what tyre pressure
    Just picked up a a4 avant with 18' rs4 reps, what tyre pressure should I be running them on?
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    You can find a tyre pressure label inside door pillar
    30
    Quote Originally Posted by CMD View Post
    Sorry I have seen that but I thought that would only apply if I was running standard wheels, is that not the case?
    Apr 2009
    Shirley, Solihull
    542
    My Cab was fitted with the optional 18" BBS alloys with 235 tyres and the handbook/sticker both advise 42psi front and rear, I (and others) found this pressure a bit harsh so have gone for 38psi front and rear.
    HTH
    mark
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
    30
    Quote Originally Posted by markyzs180 View Post
    HTH
    mark
    Cheers mark I will try 38 psi
    Xmay4444's Avatar
    On Point!!
    Nov 2008
    LHR
    255
    I dont matter wether they are reps or not, as long as the tyre size is the same follow what is on the pollar.
    Remember, the cab will be heavier than the standard car.... I think
    1.8T quattro S-Line in Akoya Silver, Milltek sports cat & 100mm tipped pipes, black Angel Eyes, 18" RS6's (Vredestein Ultrac Sessanta), Bose Symphony 6CD, Moonroof, Criuse Control, Armrest, Full DIS, 0.5 Leather, F&R PDC, Light Pack, Parrot MKi9200
    Coming soon HID's
    2001 1.8T Sport 0 v Swedish Artic 1
    wallacr's Avatar
    Nov 2003
    241
    I run my 19" RS4 reps at 32-34 PSI
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    Standard pressures for 235/40R18 tyres on my 1.8TQ are 36psi
    A4 Avant S-Line quattro - Avus Silver/Silver Half Leather *240ps*346nm* - a few choice mods. Now Stared up ;-)
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Cheers Bub, I think that is the first time I have ever seen a definitive answer to that question
    Million miler
    Apr 2009
    North Yorkshire
    37
    Vredestein
    I recently replaced a couple of my 235/40/18s with Vredestein Ultrac Sessantas, their website has a pressure calculator which recommended a whopping 3.5 bar front and back, (equivalent to 50 psi!):
    http://www.keepthepressureup.com/tir...e.asp?TaalID=3
    I tried this for a couple of days but it was pretty harsh so I then reverted to my previous 38 psi front / 36 psi back. At these pressures the turn in is not particularly sharp but then tbh the A4 steering is hardly razor like anyway and I'd rather keep my fillings a bit longer.
    May 2007
    Chorley, Lancs
    781
    I run my 18" RS6 replicas with 235 40 ZR 18 tyres at 41 PSI front & back...
    ......if you run them too low the fronts outer edges wear out to quick......hmmm, or that may be down to my enthusiastic driving style...
    Monza Silver A4 2.0TDi S-Line Avant Quattro (170) - Heated Alcantara Leather, Sat Nav, Bluetooth, Folding Door Miirrors, Electric Tailgate, Privacy Glass, etc
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    JC - are those 8J wide?
    thanks Bub - where did you get that from... tyre pressures are car and wheel / tyre spec specific, not by tyre manufacturer, aren't they??
    I've heard 40-42psi for mine.... but then the 2.5 V6 TDI (Quattro) is gonna be a lot heavier than a 1.8TQS, so that would make sense!
    Wilo never said which car, wheel width or tyre specs, so it's all goign to be very approximate advice until then...
    LostBok/BahnStormer77
    May 2007
    Chorley, Lancs
    781
    lostbok.....not sure - I think so...but will check tommorrow !
    BahnStormer
    Feb 2009
    Surrey
    2,582
    I also assume there's an element of different pressures for different tyre widths? So a the 235/40/18 S4 tyres are going to be different from the 225/40/18 (and 215/40/18) that are A4 spec.... or the 205 width that a lot of people fit for cost reasons, even though they screw with the final drive ratios due to the reduced circumference.
