Badger5Sky Insurance
Results 1 to 21 of 21
    V6 Quatt's Avatar
    Feb 2008
    783
    Day Time Running Lights for B6 is it possible?
    Is it posible to fit Side light Day Running Lights like the B7 to the B6 models
    Torque the Torque
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    i think i've read somewhere that you can program the sidelights to be drl's using vagcom, i'll have a search about
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    right, not tried these myself but according to the ross-tech wiki you can program drl's in vagcom
    Central Electrics Channel 008: Daytime Running Lights
    0 = Daytime Running Lights OFF
    1 = Daytime Running Lights ON
    I found this coding as well:
    Module Central Electrical
    xxx?x: Headlights
    0 = Halogen Headlights w/o Daytime Running Lights (PR-8Q0/8Q1+8K0/8K7)
    1 = Halogen Headlights with Daytime Running Lights (PR-8Q0/8Q1+8K1/8K3/9C6/9C7)
    2 = Bi-Xenon Headlights with Daytime Running Lights (PR-8Q3/8Q5+8K9/8K4)
    3 = Bi-Xenon Headlights w/o Daytime Running Lights (PR-8Q3/8Q5+8K0/8K7)
    4 = Bi-Xenon Headlights with Daytime Running/Tail/License Plate Lights (PR-8Q3/8Q5+8K1/8K3)
    V6 Quatt's Avatar
    Feb 2008
    783
    Thanks.
    Has any one tried it.
    Quote Originally Posted by 1210tech View Post
    xxx?x: Headlights
    Torque the Torque
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    i'll try it when i get home tomorrow
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Good man
    What bulbs does it use do you know? The dipped beam headlights?
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    dunno i'd imagine it would be the sidelights but we'll find out
    Mar 2008
    Dorset
    13,856
    Sidelights would be pretty dim - non-xenon cars only have 5w bulbs?
    scottie123's Avatar
    Oct 2008
    1,888
    it will permantely put on your front lights... dipped and side.
    well it does on the a3 anyway so i presume it will be the same
    05 SB SE BKD
    Build Thread
    V6 Quatt's Avatar
    Feb 2008
    783
    Good man. Please post some pictures when you have a result.
    Torque the Torque
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    ok just tried it.
    apparently my car doesn't have channel 008 on the central electrics module so couldn't do it through adaption so i tried it by changing the coding from 00001 = Rest Of World to 00002 = Northern Countries (Finland etc) and it worked.....but i have retro fitted oem xenons and they didn't like the new coding one bit
    the sidelights & dipped headlights came on with the ignition but the xenons flickered then the drivers side went out and wouldn't come back on again. i reset everything back to original and the xenons were fine
    so it can be done, and i reckon if i removed the xenons and re-fitted the standard halogens it would work.....but i can't be arsed with all that
    Mar 2008
    Dorset
    13,856
    ok just tried it.
    Why do you think they work with halogens but not retro fit xenons then? Sounds a weird one.....
    I think the US running lights is just front lights, but the Scandinavian setting will illuminate the tail lights too, is that right?
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    I thought it might be because my car doesn't have channel 008 so I couldn't tell it that xenons are fitted and then when I changed the country the coding wasn't correct as per equipment fitted.....maybe, maybe not, but I just can't bothered to swap the xenons out with the halogens just to try, lazy I know
    I didn't check the tail lights, I was a bit busy sorting out the front end after the xenons started playing up
    V6 Quatt's Avatar
    Feb 2008
    783
    Thamks for checking. I have OEM Xenons. Neve simple is it!
    Tought you had it solved. Damn
    Torque the Torque
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    Quote Originally Posted by V6 Quatt View Post
    Are they factory fit xenons? If they are then you should be able to program the DRL's through the adaption channel rather than changing the coding. I think mine don't work because, although they are oem xenons, they weren't factory fitted so the module that controls them wasn't programmed to control xenons, i think this is why my module doesn't have channel 008 on the central electrics module.
    I wouldn't give up trying to do it this way. Try and find someone near you that has vagcom or vcds as its now called and give it go
    V6 Quatt's Avatar
    Feb 2008
    783
    Thanks. I will try and find someone to test this. Yes my Quattro has factory fit Xennons. What side light bulbs would be used to get this effect.
    Torque the Torque
    Dec 2009
    hey, wondered if you ended up anywhere with this? Looking at setting up the DRL's without the tail lights on an A4?
    the matrix is comin
    Jan 2009
    ramsgate
    147
    on ebay you can buy r8 look ones for bout 20 and fit them in your head lights on a sep switch or like me i've put them in my bumper on my b5. they are only a strip of led's
    built in germany caressed and loved in england.
    Aug 2009
    833
    Quote Originally Posted by stub View Post
    but soooo many chavs have them.
    the matrix is comin
    Jan 2009
    ramsgate
    147
    maybe but not round here. but still they only look rite on an audi. i mean how out of place do they look on other cars at least they were ment for our cars not ford vauxhalls pugs etc.
    Aug 2009
    833
    Audi wernt the first.
    Aston Martin
    Rolls Royce
    and now almost every new car is coming with them E class merc, porsche. Personally not to my taste even standard.
