Volks AutosAH Fabrications
    Mar 2008
    9
    A4 TDI Jerky Engine On Idle...
    Hi
    Just wondering if anybody could help me at all
    when i first start the engine the car doesnt feel right its really jerky through the pedals and all the car, when you apply a little revs the car feels normal again i have used vag-com to see if they is any faults but nothing. i had a similar fault about 10 months ago and i replaced the engine mount on the right side of the engine (the one with a sensor)
    Could it be any other engine mounts?
    Someone has said it could be the dual mass flywheel?
    I would appreciate if anyone has any ideas
    Cheers Sam
    white.akita's Avatar
    May 2008
    county durham
    280
    i think it could be either the dmf, engine mounting or an injector but a injector should show a fault code.
    if you have had a faulty engine mounting then the others will of been under alot more stress so could be another mounting.
