EM TuningBadger5
Thread: Engine Trouble
    Renbod's Avatar
    Feb 2009
    UK
    118
    Engine Trouble
    I'm not sure if I'm experiencing the "limp" mode but when my car boost slightly over 1bar the boost drops to 0bar and it wont boost any higher.
    Then it struggles to get over uuhm 60mph and even struggles to pull away from a focus. If I re-start the ignition it's seems to re-set something and drives fine until boost hit's 1bar again. I don't have any lights on the dash and I don't have VAG com (yet) so I can't see what the problem is.
    Does anyone know what could be the issue? It sound's like a sensor issue to me but I'm not sure what or where.
    It's a 1.8t (190) and hasn't been chipped but I do have a pipercross panel filter and a forge 007 dv, although these have been on the car for month without any problems.
    Carl
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Your car shouldn't be boosting as high as 1 bar tbh. S the oor car is puttig you in limp to protect itself.
    You need to get it scanned to see whats going on. My bet is N75 valve not regulating boost as it should
    Renbod's Avatar
    Feb 2009
    UK
    118
    Cheers Byzan, I'll see if I can get it scanned. If I need a new N75 valve I might aswell upgrade to a J or N
    Renbod's Avatar
    Feb 2009
    UK
    118
    It's fixed
    I spoke to my mate who works for Audi, he said it's one of three things:
    1)MAF
    2)N75
    3)Pressure Sensor
    I disconnected the MAF for a day but still had the same problem, so it wasn't a MAF issue. I took the car over to him last night and he cleared a few error's then took it for a spin, he then re-checked the car for errors and could see "turbo/super charger overboost condition". He also found a spare pressure sensor so swapped it for mine, I've re-tested the car this morning (on an empty M4)and it's perfect, it's holding boost at 1bar and when shifting gears I'm sure I saw 1.3bar (but I might need to re-calibrate my gauge).
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Pressure sensor? Do you have the part number?
    Renbod's Avatar
    Feb 2009
    UK
    118
    Yep, the part number on my broken one was 038906051D but the only spare my mate had was 038906051C. The annoying bit is GS&F don't sell them so i'll need to get one from a dealer for 65+VAT
