Results 1 to 14 of 14
    Mar 2008
    42
    Question ESP and Battery Warning Lights
    Hi All
    Just wondering has anyone else had a similiar problem with their 130 TDi Sport. My ESP light came on a few weeks back, I felt a vibration through the engine at the same time, so I stopped, turned the car off and back on and it was fine. I read in the manual that this can happen, so wasn't too bothered, that and the car is due a service so I thought I'd get it checked then for vag com codes.
    Then I was coming home last Thursday and the ESP light came on again, I was stuck in traffic so turned it off and back on, ESP light came on again and the battery light starting flashing. There was a vibration like the engine was wobbling too much when the ESP light came on. I got the car home and haven't driven it since. I'm using my better half's car till I get to the garage. But I'm just worried if this is going to be a costly fix.
    I had read that it could be lights sometimes, but I only changed the indicators and sidelights and my brake lights seem to be fine....oh and I fitted a new battery just before Christmas
    Cheers for any help
    Mark
    Current:
    2001 Amulet Red A4 Avant Sport 1.9 TDi
    Gone:
    2000 Goodwood Green S6 Saloon 4.2 V8 340bhp
    2000 Reflex Silver Golf 1.9 GT TDi
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    ESP also involves the ABS as well mate, but I saw too that it says if the ESP light comes on, and goes off later its ok (?) - weird eh!
    Could it be the ABS pump causing the vibes?
    Did you get it scanned for codes yet?
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    Mar 2008
    42
    yeah i'd have thought that the light just comin on of its own accord can't be good...
    i'm ringing the garage today and hopefully get it in soon
    thanks for the reply
    Current:
    Gone:
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Could be the Brake switch has this is what happend to mine and after replacing the switch for 8 it sorted the problem out.
    Mar 2008
    42
    thanks Doc, I had read that alright but the brake lights seem to be workin OK, is there anything else that would be associated with the brake switch that I would need to check??
    Current:
    Gone:
    jase0851's Avatar
    Oct 2004
    yorks
    782
    i get brake switch error codes every now and then i will have to change mine eventually
    EBONY PEARL 2003 1.8T SPORT GMBH 190 AVANT 19" GALLARDO,S S4 SILVER SILK NAPPA HEATED RECARO,S MATT ALI MIRRORS,O.CT INTAKE PIPE, B7 DTM VOTEX SKIRTS, HYPERBOOST HX DIVERTER VALVE, RS4 DOORCARDS+TRIGGERS, AUTO-DIMMING REAR VIEW MIRROR, RS4 BRUSHED ALI TRIM, RS4 START BUTTON, PIPERCROSS PANEL FILTER, RIEGER INFINITY FRONT BUMPER:: NOW REMAP,D TO 240 ISH BHP OMG WHAT A DIFFERENCE
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    My brake lights worked fine but some how the switch is linked in to the ESP and ABS and although my brake lights worked OK the switch still took out the ESP & ABS my brake lights only stopped working after I took the switch apart.
    I should add the fault would come and go but in the end it stayed on and thats when I took the switch apart also Audi have upgraded the part so it's a know fault at Audi.
    Mar 2008
    42
    thanks Doc, I got a switch last night and got it in, seemed to be fine until the ESP and ABS light came on and now when I turn the car on the brake warning symbol is appearing in the DIS and its beeping, can't be good. I'm going to swop back to old one to see what that does and refit the new just to be sure.
    The battery light is still flashing as well.
    Car is booked into the garage on Monday, so we'll see....
    Current:
    Gone:
    Mar 2008
    42
    so this all might be a bit more than originally thought.....
    I've changed the brake switch and when I turned the ignition back on the brake warning light appears on the DIS and it beeps three times, brake light work OK though
    And then all the lights started to flash on the dash and all went dead. I turned the ignition off and tried to start again it wouldn't even turn the engine and all the lights on the dash would go out. I tried to jump it this morning from another car, it starts but then dies after 30seconds, oh dear.
    I was supposed to be taking it to the mechanic today, but I might have to rethink that.....
    Current:
    Gone:
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    dodgy battery or battery connection mate i'd say, and then the immob maybe threw a fit when you reactivated the ecu with the jumper car?
    Try connecting the leads and leave connected for a few minutes, then turn on the ignition and see the check go out before starting attempts to give the immob time to hand over. The original faults could have been battery related but the shutting down after 30 secs sounds like the immobiliser.
    weird, but I had some strange behaviour before I changed my battery, lights glowing inside while driving then dimming out, stupid esp warnings at walking speed while parking etc etc, forgot about that
    Mar 2008
    42
    Right so, after all the above, the flashing battery light was a dodgy alternator pulley on the front of it apparently, so that was fixed along with the alternator getting refurbed and the battery light has gone, but the ESP and ABS lights are still coming on, but not immediately only after driving and not always at the same time, some times its after 5mins of driving other times could be 20mins. Weird....
    My mechanic isn't too worried and says it could be from all the messin around with the battery, could have tripped some sensors that need reset, its going to him to get sorted this Monday
    Just thought I'd post a quick follow up in case anyone else comes across the same problem, will update on the rest next week
    Current:
    Gone:
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    hmmm try getting the codes cleared and see if they return again.
    Mar 2008
    42
    The saga continues, the car was serviced yesterday and the mechanic said the only codes that were showing were associated with the low battery when the alternator was banjoed, so he cleared them all and thought it should all be good. But driving home last night the ESP and ABS lights popped on again, still really random though they were on after 5mins on the way home and then again immediately when I went out for a cycle, but on the way back home no sign of them for a good 30mins drive.....Have to pop back down today to the mechanic to see what the crack is
    Current:
    Gone:
    Mar 2008
    42
    So it would seem the fault is this
    01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
    Possible Causes
    • Brake Pedal Switch (F) faulty/jammed
    • Brake Pressure Sensor 1 (G201) faulty
    Possible Solutions
    • Check/Replace Brake Pedal Switch (F)
      • See Measuring Blocks
    • Check/Replace Brake Pressure Sensor 1 (G201)
      • ABS Hydraulic Unit (N55) may need to replaced
      • Perform Brake Pump Bleeding
      • Perform Brake Pressure Sensor 1 (G201) Basic Setting
      • Replace Brake Electronics Control Module (J104
    The brake switch that I fitted is working as the mechanic checked it through vag com, so it would seem to be the pressure sensor.....
    Current:
    Gone:
