Badger5JMB Retrofits
    Feb 2009
    Aberdeen
    34
    Another vag com help
    my car has felt a bit sluggish this past week, so a mate offered to vag com it for me and these are the faults he found.
    16698- Single cylinder misfire
    17912- Intake air system bypass
    16784- EGR flow malfunction
    any clues what I should be looking for?
    forgot to say its a 2003 2.0fsi with a lot of millage
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    those are probably not totally related mate, but may be 2 faults. Check the intake pipework for leaks or cracked hoses, and you may need a coilpack, don't know if the misfire was due to the air leak since unmetered air would be getting in and causing lean running.
    The EGR valve is exhaust gas recirc to cool combustion chamber temperatures, I think the valve may be stuck.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    Feb 2009
    Aberdeen
    34
    So I should check the intake after the air flow meter for a leak.
    I did have a thermostat problem so I wonder if that is related or cause the EGR problem?
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    yes to 1, no to 2 - the egr is Exhaust Gas Recirculation valve - nothing whatsoever to do with coolant, plus its mechanical / vac operated. Could be on the leaky line if you have one, so that its not opening due to low vac or air leak.
    Check first for leaks on all air and vac pipes (might need to use a boost leak tester) and take it from there, thats probably whats wrong wi it mate.
    An air leak would not make just 1 cylinder misfire tho, that could be a coilpack / plug faulty or a fluke from the weak mix.
    Feb 2009
    Aberdeen
    34
    I did a quick search after you said coil pack and found on other threads similar problems that I've had in the past week (really rough idle with bad vibration)
    I've ordered a coil pack and had a quick look over the pipes but nothing obvious.
    Sep 2009
    Did you ever resolve this?
