EM TuningVolks Autos
    Mar 2009
    Derbyshire
    27
    Replacing front indicator bulbs
    I need to replace the front nearside indicator bulb of my A4 (51plate), it doesn't seems as simple as with most cars. I'm guessing you need to slide out the headlight unit (or whatever it is called). I've worked out that the two screws at the top that need to come out, but there is something holding it in place at the bottom - any advice?
    Oct 2008
    Swindon
    44
    if you look down between the gaps behind the headlight unit, theres another 2 more screws underneath , dont take it right off just loosen it then you be able to remove the headlight
    2001 Audi A4 2.0 Auto - HID's - 18" RS4 Alloys
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,689
    Taking the lights out is pretty easy really. You just need to have a long enough Torx driver to get the lower screws loose. This guide should help:
    henry74's Avatar
    Feb 2007
    Verwood, Dorset
    115
    James - do you get some commission/royalties every time you put those headlight removal diagrams in a post?!? Only joking mate - if it wasn't for guys like you lots of people would struggle with what should be a simple job like changing bulbs! By the way (to hijack this thread a tadge) what would LED sidelight bulbs look like with standard main bulbs - cack or no?
    Mar 2008
    Dorset
    13,689
    Quote Originally Posted by henry74 View Post
    Lol it's the only useful diagram I have and I like to get my moneys worth out of it!
    Dunno if it would look cack, but not sure it would look great, while you are fitting the LED's you might just as well fit some HID's ......
    Mar 2009
    Derbyshire
    27
    Thanks for the instructions - worked a treat!
