Volks AutosJMB Retrofits
Results 1 to 9 of 9
Thread: Thanks Audi
    Steve_N's Avatar
    Derv Power
    Apr 2008
    Gosport, Hampshire
    203
    Thanks Audi
    Had the car MOT'd on the freebie from Audi, and the it passed with only a couple of pick ups. One being the the rear pads and disks are close to being 100% worn. How easy is it to change these or is there some special tool needed because of the handbrake connection. I know from when i had the LCR you had to have a special tool to wind the piston back in are the Audi's the same. By the way its a 2004 1.9TDI Sport.
    Black LCR now gone
    Blue A4 Avant in its place
    Nov 2008
    Darlington, England
    181
    Should be very easy. Not sure of the back brake design but even if you need to do what you said there. You dont need that tool. You can just use a chisel/screwdriver and a hammer and work the piston round until it goes back enough to get the new pad in. The tool just makes it easier.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Chisel Screwdriver & Hammer.......What you telling him to do ronnie, Smash the Discs off!!lol...
    Make sure the cap is off the reservoir and I used a rubber coated bar to prise the pistons further apart, dont need much pressure at all...Thats how to be a Gentle Butcher!!
    Renbod's Avatar
    Feb 2009
    UK
    118
    You don't need the special tool mate, I've found two easy ways of doing it:
    1) Use a large G clamp, as you wind it in it winds the piston in.
    2) Use a pair of circlip or snipe nose pliers and just wind it in.
    Eeeeeaaaaassssyyyy!
    Oct 2005
    Lancashire UK
    202
    Quote Originally Posted by Renbod View Post
    Eeeeeaaaaassssyyyy!
    I didn't have a G clamp so got the tool for about 7. Takes 20 seconds...
    2001 - Silver A4 1.9TDi Sport
    Nov 2008
    Darlington, England
    181
    Quote Originally Posted by J7USS View Post
    LOL.
    Wasnt sure if it was the twist style pistons on the back or not. Thats the way I have done loads in the past like that. But as you said if its the easy type. Essentially all you need to do is force the piston in one way or another. Remembering to take the cap of to allow the fluid to be pushed through the pipes. Be careful with the brake fluid. I would put a cloth round the reservoir just incase the fluid comes out as you push the piston back in.
    Xmay4444's Avatar
    On Point!!
    Nov 2008
    LHR
    255
    Had the same advice, anybody know what the tool is called and where i can get one for that price?
    Also I've never tried it before but am willing to have a go. Anyone have a writeup on the procedure or where i can find one?
    1.8T quattro S-Line in Akoya Silver, Milltek sports cat & 100mm tipped pipes, black Angel Eyes, 18" RS6's (Vredestein Ultrac Sessanta), Bose Symphony 6CD, Moonroof, Criuse Control, Armrest, Full DIS, 0.5 Leather, F&R PDC, Light Pack, Parrot MKi9200
    Coming soon HID's
    2001 1.8T Sport 0 v Swedish Artic 1
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    I just used some needle nose pliers when i did ours, they should easily wind in with those.
    I dunno if it will actually need new disks though, unless they are really badly grooved i'd just replace the pads.
    Procedures in the haynes manual, probably easiest way to find out what your doing.
    TD5 Land Rover Defender build
    May 2007
    Chorley, Lancs
    781
    Monza Silver A4 2.0TDi S-Line Avant Quattro (170) - Heated Alcantara Leather, Sat Nav, Bluetooth, Folding Door Miirrors, Electric Tailgate, Privacy Glass, etc
