Sky InsuranceJMB Retrofits
Results 1 to 15 of 15
    white.akita's Avatar
    May 2008
    county durham
    280
    which bhp engine do i have ?
    hi, how can i tell what bhp my engine is as standard ?
    i have a 2002 a4 1.9 tdi, the badge is a red i but this could be an aftermarket badge.
    i recently bought it so dont have the full log book yet, is there any way of telling looking at the engine ?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Have a read of THIS thread.
    Jun 2003
    World of my own
    9,813
    Just look at the sticker in the spare wheel well, power should be 95kW for the 130bhp red i model, or 80kW for the 110 model.
    Alex Turner
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,534
    Red i usually means a 130 - that's the badge that was on my 1.9TDi 130 Sport.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Mar 2008
    Dorset
    13,856
    I think he wants to just double check in case someone has put a red i badge on.
    May 2008
    county durham
    280
    thanks guys just checked the sticker in the boot it says 96kw so it is the 130bhp model.
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    also, aren't the 110bhp all 5 speed and the 130's 6 speed? or is that just the VW's (Mk4 Golf, Sharan, etc)?
    LostBok/BahnStormer77
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,534
    Quote Originally Posted by lostbok View Post
    I think so.
    May 2008
    county durham
    280
    no, i have a 130bhp 5 speed and so does a work friend.
    technics100's Avatar
    Feb 2004
    Co Antrim
    774
    I had a 5 speed 130bhp A4 avant too. Now my sticker says 250KW... Ah well
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    BahnStormer
    Feb 2009
    Surrey
    2,582
    just found it... for the 1.9TDi there's the regular SE and also a "6SE" and the same with Sport and a "6Sport"... 1.9TDi 130 available in both categories...
    110Tdi only in 5 speed.... so I was half right (clutching at straws, aren't I?)
    Aug 2004
    Aberdeenshire
    740
    130 changed from 5 to 6 speed at some point in 2003 IIRC. Torque was also upped from 210 - 228 lb/ft at the same time.
    The B6 was never available with the 110 engine as that's pre-PD so only in the B5.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    there was a 110 or 115hp PD motor for sure, as this was fitted to later model B5's
    Dunno if it was carried over to the B6 though.
    TD5 Land Rover Defender build
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Aragorn - I was about to agree with you, but I think you're only partially right (the 110bhp wasn't a PD).
    Macduff - not true B5's and B6's both came in PD (Pumpe Duse) and VP (Verteilerpumpe) flavours of 1.9 TDI and definitely not PD in the 180bhp-230bhp 2.5 V6 :D
    I had a quick look and it seems that although there are VAG 1.9TDI at countless different bhp ratings, it would seem that the PD come in 100, 105, 115 and 130bhp.... but the 110bhp TDi's that went into first of the B6 A4's are actually the older VP37 flavour....
    Which would explain the 5 speed being changed for a 6 speed to take advantage of the PD's increase in torque and compensate for it's narrower power band compared to the Verteilerpumpe TDI's.
    Aug 2004
    Aberdeenshire
    740
    OK, I wasn't specific enough. AFAIK, the 1.9 in the B6 was always PD. I've never heard of a VP 1.9 in a B6. The 1.9s were only available in 100 and 130 initially and both 5 speed. The 130 changed to a 6 speed and the torque was increased around 2003. The 115 engine was a late offering before the B7 came along. It was Euro4 compliant whereas the previous 1.9s had all been Euro3.
    You're right about the B5. It came with the 115 1.9 in the last year or so of its life. I had thought it only came with the 90 and 110 VP engines.
    Away from the A4, the 1.9 PD engine has been offered in power outputs from 100 - 160 PS.
