Sky InsuranceAH Fabrications
Results 1 to 35 of 35
Thread: 12v power
    Nov 2008
    25
    Red face 12v power
    Hi there
    Can some one please tell me where i can find 12v switched power under the hood to use for some led's ?
    Nov 2008
    25
    Audi 1.8T sport
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Comes as a standard fitment on a Corsa and a Rover 25, but not on an A4.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    x2
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    Lets face it, we were all thinking it!
    A4 Avant S-Line quattro - Avus Silver/Silver Half Leather *240ps*346nm* - a few choice mods. Now Stared up ;-)
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    but thanks for saying it!
    LostBok/BahnStormer77
    Nov 2008
    25
    Ok not one are as clever as you think.I want to now where you can tap of 12v switched
    under the bonnet.WISE ASSES
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,299
    I think you'll find you got the reply you did because stick on LED's are seen as a bit tacky/chavvy....
    As people said, its the kinda thing you expect to see stuck to a corsa thats being ragged around the local tesco car park at 11pm.
    I dont think there will be any ignition switched lives under the bonnet, or at least, not any that you should be tapping into.
    What exactly are you trying to achieve?
    TD5 Land Rover Defender build
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Ever the diplomat Aragorn....
    I can't believe I'm going to be complicit in doing this to an Audi, but....
    Should you wish to hypothetically wire up some low voltage lights from under the bonnet - it might be an idea to check the voltage on the lines that run to the running lights (aka "side" or parking lights... i.e. the ones that go on when you turn the lights on one notch). A few LED's would probably be okay - but bear in mind that in the unlikley even that if you start drawing too much current on that circuit and blowing fuses, it will also "trip" (switch off) the running lights and technically render the car illegal and you'll get pulled over.... but by the sounds of it, that may not be the rozza's main reason for doing that
    Nov 2008
    25
    HI go see this
    http://www.audizine.com/forum/showthread.php?t=205172[IMG]file:///C:/DOCUME%7E1/Theo/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG]
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    So you wantr the Led's for your Headlamps?? If you was that specific then You would have had more serious Answers mate.
    Mar 2008
    Dorset
    13,856
    Commonly known as Daytime Running Lights or DRL's
    BahnStormer
    Feb 2009
    Surrey
    2,582
    ha ha - Theo, you would have got a LOT less abuse for that.... not exactly to my taste, but there's nothing wrong with blending in a few other Audi OEM looks
    We all though you were after one of those particularly tacky kits....
    And we would have recommended something like this for inspeiration for a body kit:
    Mar 2008
    Dorset
    13,856
    If they were heated washer jets i would get them.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    A Sniper on route
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Quote Originally Posted by J7USS View Post
    A Sniper on route
    That seems liek a lot of effort for one person..... just import a supply of big furry dice that explode when they get within 6 feet of UV tubing....
    "Stick a V8 in it!"
    15,299
    If you want it on with the sidelights, then just splice it into the sidelight wiring, the extra power wont be an issue.
    If you want them on all the time with the ignition, then you want the connection labelled 75X in the central electrics panel behind the dash.
    Nov 2008
    25
    aragorn
    Thanks the only one not afraid to help.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    im sure someone on here has purchased a set of headlights that have the leds in which fit the b6 that are alot more OEM look than a diy kit, have a search on previous posts.
    LOTS DONE, LOTS SPENT !!!!
    Nov 2008
    25
    Light strip
    Hi there this is it.
    Nov 2008
    25
    "Stick a V8 in it!"
    15,299
    i dont see anything?
    Mar 2008
    Dorset
    13,856
    Got any bigger pics?
    So is that your car after the conversion? Or a picture of the car with the conversion you are hoping to do?
    Looks good though.
    "Stick a V8 in it!"
    15,299
    I still dont see anything, where have you hosted the images?
    Mar 2008
    Dorset
    13,856
    Sometimes they seem to work and sometimes not
    Try this:
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    ...am I missing something...literally!! Cant see a Pic at all..
  28. #27
    Mar 2008
    Dorset
    13,856
    I give up!
    Sometimes they are there, and sometimes they aren't! Must be a problem with webshots, the image host.
  29. #28
    Nov 2008
    25
  30. #29
    Jul 2008
    334
    i reckon they dont look too bad... how long did it take you?
  31. #30
    Nov 2008
    25
    About half of Saterday.
  32. #31
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Dont look to bad do they. How did you find the task of getting inside the Headlamp?? Did you have to bake them for a while to release the seal??
  33. #32
    Nov 2008
    25
    I have cheated .is under the light did not have the nerve to open stock lights.
  34. #33
    "Stick a V8 in it!"
    15,299
    The B6 lamps dont come apart with baking, you need to do a lot of prizing and levering at them to get them open.
    See this guide: http://www.a4mods.com/index.php?page...tml&category=3
    I've done the same thing to my B5 lamps. Looks a lot better imo. I hate shiney chrome though.
    http://lr90.org/Audi/lights
  35. #34
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    ...ahem Yes They Do. You put them on a low bake instead of the heatgun method (again, by Choice), Many have done it including Rocko on here and loads on Audizine. Infact everyone who I asked did it that way...
    Do a search through Rocko's threads, you'll see
  36. #35
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
