Chris NottAH Fabrications
Thread: Air Bag Light
    Seifer780's Avatar
    Feb 2009
    Clinton, Utah
    67
    Air Bag Light
    2003 Audi A4 Quattro 5-Speed. Came on after a normal right turn. Dealer cannot find anything wrong with it, and the airbag mechanism checks out.
    Any suggestions?
    Light travels faster than the speed of sound, which is why some people appear bright before they speak.
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    check the cable connection under each seat, that goes to the seat belt pre-tensioners hasnt unplugged itself, that will cause an airbag light.....and the car should have shown a DTC fault code....how did your dealer not find a code?
    You cannot possibly have an airbag light on with no error code in the ecu / airbag controller.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,378
    Quote Originally Posted by evilscotsman View Post
    Seconded
    If the dealer told you they cant find a fault code, when the dash light is on, NEVER take your car anywhere near them again, as they're clearly a bunch of chumps.
    Perhaps someone near you on the forum with vagcom will be able to help?
    Its likely to be either the side airbag connectors under the seats, or the contact ring in the steering wheel. The fault code will tell you which, and the light WILL stay on until the codes are cleared, even if you fix the fault.
    TD5 Land Rover Defender build
    Marc1's Avatar
    Feb 2008
    721
    If you can't find anything obvious under the seat, look for signs of charred wiring or broken connections whilst you're there. Unplug all the connectors, replug, take to a specialist or fellow member with VAG-COM to remove the fault, it will reappear if there is still an issue, but may not clear if you don't disconnect / reconnect the plugs first.
