Chris NottSky Insurance
    Seifer780's Avatar
    Feb 2009
    Clinton, Utah
    67
    Drivers Side Mirror
    2003 Audi A4 Quattro 5 Speed. The drivers side mirror was hit by debris. A piece of plywood that flew out of the back of a truck, unfortunately. The casing and the mirror are still secure for the most part, but if there is any wind or vibration, it will vibrate, causing a strobing effect making it difficult to see what is behind.
    How can this be repaired?? Can the mirror be salvaged cheaply, or will this require a brand new part?? I would prefer to keep the current mirror as it is in ok condition with the obvious exception of it being not completely stable. It's not dangling by the wires or anything, but not solid like it should be.
    Light travels faster than the speed of sound, which is why some people appear bright before they speak.
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    Jeesus you have no luck mate. You should stay at home, away from trucks, mcdonalds and right turns - lol
    The mirror is screwed to the door behind the plastic triangle trim. The glass is on a pop-in plastic ball-joint - you need to disassemble the mirror and see whats broken, then replace or repair the broken bits... (Or take one off a breaker car)
    Careful with the wires....
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
