Sky InsuranceJMB Retrofits
Results 1 to 14 of 14
    silversurfer's Avatar
    Jan 2007
    221
    After market Double Din Head Unit
    Hi,
    I'm after some help.. Does anybody know my double din kenwood head unit would fit with the below climate control unit..?
    I presume the Climate unit moves to the bottom and the head unit then fits in above..? Or do I need a different Climate unit
    Neil
    Jan 2007
    Hampshire
    1,155
    You need a different climate unit or you need to trim the edges of your current unit.
    A6 3.0 TDI.
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    As Issac Hunt said above you can use your own climate unit and trim the edges but you'll need a new double din cage, you can see how to fit one from theis gudie http://www.harddrive.plus.com/Docume...%20in%20A4.pdf
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    wot them lot said
    You'll need a new cage and then either replace the climate control unit with the narrow version or take it out, trim down the edges (apparently they're actually marked out where to cut) and then as you had mentioned: reseat it lower in the dash.
    LostBok/BahnStormer77
    Jan 2007
    221
    Nice one.. Thank you..
    Jan 2007
    221
    Quote Originally Posted by lostbok View Post
    Does anybody know the audi part numbers of the cage I'd need.?
    Thanks Neil
    technics100's Avatar
    Feb 2004
    Co Antrim
    773
    no part number, but here's one here.
    http://cgi.ebay.co.uk/Original-Audi-...1%7C240%3A1318
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    Jan 2007
    221
    Is it difficult to replace the cage..? And from the look of the above Ebay link the same part is used for the B6 and B7 A4's. Is that right..?
    Feb 2004
    Co Antrim
    773
    try this, should be enough info for you.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    did mine myself, fairly straight forward, but not a two minute job, allow an hour or two
    LOTS DONE, LOTS SPENT !!!!
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,525
    Quote Originally Posted by silversurfer View Post
    Yes, the B7 was just a facelift of the B6 not a completely new model.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    BahnStormer
    Feb 2009
    Surrey
    2,582
    that's right... B6 and B7 parts often interchangable.... especially in the dash.
    My B6 has the "MMI" version of the RNS-E.... not that I know what the MMI version looks like - might just be the splash screen, but a friend reckons it's very different from what's in his 2003 B6 ;D
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,525
    Your friend doesn't have an RNS-E in his 2003 B6 - he has it's predecessor, the CD based RNS-D (like I had in my 2003 B6 S4). That has a non-motorised screen, doesn't take SD cards and has two large knobs to control it instead of the one that the RNS-E has. They are very different systems.
    The RNS-E has absolutely nothing in common with the MMI in the A5/A6/A8/Q7 - it makes me really angry that some idiot at Audi decided to make the RNS-E show "MMI" on start-up. It doesn't share ANY common parts, and it doesn't use the same map DVDs. I've seen dozens of people spend 200+ on an MMI DVD because their RNS-E says "MMI" - only to find the DVD they have bought is totally useless to them.
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Thanks for clearing that up, Dave.... makes a lot more sense now.... I thought somebody had just done a dodgy hack-job on my RNS-E to give it the MMI splash screen!!
