AH FabricationsBadger5
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    has the waterpump failed?
    A4 1.9 TDI 130BHP 2001 B6.
    TEMP is half way reading 90 as always.never starts to climb.
    water in coolant bottle =cold even when engine hot.
    took expansion (coolant bottle cap) off and left it off, incase there was air in system.....no change.
    car is loosing coolant,cant see any leaks.......any ideas?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    If the water pump was failing then I would have thought that the car would be overheating, I would think more likely the thermostat has gone.
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    if it were the thermostat,would the car be using coolant? like i t was filled to maximum level then 120 miles later (motorway journey) after an hour of resting the water level was just under minimum
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    exactly the same problem as I have mate, its the coolant flange behind the head that 2 pipes and the temp sensor are connected to, its a tenner from the stealers but awkward to get to. I thought it was the pump as well but have now seen the water leaking from the rear of the head and the culprit is a plastic part that cracks or just leaks at the o-ring seal, the temp sender seal, or one of the 2 pipe ends.
    Mine is waiting to be picked up next fri and im going to attempt to replace it.
    Heres a write up I found:
    http://audizine.com/forum/showthread.php?t=84054
    from the excellent audidiy.com
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Quote Originally Posted by evilscotsman View Post
    Exactly the same prob I had also over a year ago, id have to top it up every week!
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    Nice one lads! its a friend car based in rochdale....any good audi mechanics in that area you know of ?
