Chris NottAH Fabrications
    Jan 2009
    Fitted new brake light and switch still problem
    Hi im new on here. Have gone through the threads with the brake switches. Ive fitted a new switch and think its adjusted properly but the lights still arent working. When the old switch is connected the brake lights are stuck on but now the lights arent working at all with the new switch. Its a 2004 a4.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    can you try pressing the new switch manually with your finger and see if it lights?
    I presume its simply a two pin switch? if so try just bridging the wires together and see if the lights come on...
    Perhaps you have a duff replacement switch?
    TD5 Land Rover Defender build
    Jan 2009
    I got another new switch from the dealer. They said I damaged the switch fitting it. Any one got any tips for fitting/adjusting it. Thanks
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,708
    I have seen a guide someone has made up for replacing the brake light switch, don't know if it's any good, but it can be downloaded from here:
    http://www.mediafire.com/?jrdiyjmttc3
    Jan 2009
    Cheers got it working anyhow. Just tried it the second time the same way and it started working, dont know what was wrong.
