Volks AutosEM Tuning
Results 1 to 31 of 31
    Aug 2004
    Aberdeenshire
    740
    Farthest driven with 0 miles remaining?
    Coming back from Inverness today, my car clicked down to 0 miles left after 583.5 miles. I carried onto the next petrol station only to find it closed so I continued and filled up at 596.8 miles (a pretty poor 41.2 average for the tank). The car took 65.8 litres of diesel (FWD 1.9 130) so assuming I could run it dry I still had almost a gallon remaining so could possibly have done another 30-40 miles.
    So, what's the furthest anyone's driven with 0 miles remaining and what's the most anyone's got into their tank without actually running out of fuel?
    BTW, is it still a ***** to re-prime a diesel if you run out? I was getting a bit concerned over the last couple of miles.
    Oct 2007
    2,597
    Wow, brave man.
    Lowest mine ever gets before refuelling is 25 mile range.
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by Siena View Post
    Wow, brave man.
    Well, I assumed it wouldn't conk out when it reached 0 and there were very few petrol stations with decent prices. One place was charging 111.9p for diesel and being a true Scotsman I always seek out the bargain!
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    i don't let mine go below a range of 25-30 miles...i'm too scared about the consequences! although i know in the back of my mind i probably actually have at least double the range left in the tank its a different story when i'm behind the wheel thinking, **** i need some diesel!!!
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    Nov 2007
    88 miles coming back from wales on the M4 as my wife had my wallet and she was with her dad but mines a petrol so if i ran out i knew that they could leave the fuel station that they was at and come to me with a gallon or two!!
    Was worried though!!
    Jan 2009
    What year is your A4? When i worked for Audi as a tech (up until around 2005) the 1.9 TDI was very straight forward to get going once ran out of fuel, we regularly had customers with lease cars brimming them with petrol, so we had to drain the tank and lines and replace the filter, but basically you just crank the engine until it fires, the 2.5 Tdi's on the other engine were not PD and sometimes had to crack off the injectors to get them going. but if your car is newer than that then im not too sure!
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    I've done about 15 miles in mine with 0 on the DIS
    I think I was pushing it a bit.......
    A4 Avant S-Line quattro - Avus Silver/Silver Half Leather *240ps*346nm* - a few choice mods. Now Stared up ;-)
    26,747
    done between 20-50 miles on various vag cars so fair bit left in tank when 0
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    ive had 30 miles on 0 and ran out on 10 miles remaining, its a guestimate based on your last measured average mpg/ I have learned when it says 15 or less you could run out anytime.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by nathan1986 View Post
    It's the last of the B6s i.e. a 2004/54 1.9 PD 130 but it's a 2005 model year.
    Quote Originally Posted by evilscotsman View Post
    Out of interest, how much fuel did it take when you filled up after running out? Mine appeared to still have almost a gallon remaining but I'm not sure if all 70 litres are usable.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    Our B5 just clicked onto 0 as we drove into the forecourt the other day, and it only took 57L of petrol. I think the B5's tank is 60 or 62L though, so 3-5L left in there.
    Also got to remember that while the tank holds 60L, the lines, filter, fuelrail etc will all hold fuel, as will the filler neck when you brim the tank. So there was probably more than 3-5L left in there. Also with a diesel, because the high pressure pump is attached to the engine, you can pretty much drain the entire tank, and the lines and filter before it will die, whereas a petrol would die as soon as the fuel level in the tank dropped below the pickup on the pump, as the rail pressure would drop.
    I think that TG episode when they drove those cars from france? shows just how much fuel is actually left in cars tanks when they read 0...
    TD5 Land Rover Defender build
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by Blackcab View Post
    Now that's brave!
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Think Ive probably done 3-4 miles when mine was on 0.
    If I reverse on my Slanted drive with say 30mls left on my DIS, soon as I start her up next, it literally drops to 0 (obviously because Im on a Wonky drive). I dont make habbit of driving on 0 though, thats the only time it happens...
    Usually ill fill up once its the "beep" and 25mls left on the DIS!
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    25 miles in my A6 with it on 0. More accurate is the fuel light which comes on with 9 litres remaining. Take your average mpg and x2 theres what you have left never mind the range on the DIS. Unless you promptly start driving like hell of course....
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    50 miles is best i have done, and on refill she had nearly 6 litres till 62L
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    I've managed 40 miles, but for 15 of these miles I was literally coasting.
    technics100's Avatar
    Feb 2004
    Co Antrim
    772
    I have done about 5 miles with 0 from a cold start i my S6... not good as in traffic the mpg is 12.8 in the book... you can actually smell fuel out the exhausts when cold...
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,708
    I feel quite tame now! I thought I was pushing it as i coasted into the garage just as it clicked down to 0 miles! I think I put 61 litres into a 66 litre tank or similar so could have gone miles yet!
    @ blackcab for doing 88 miles
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    I have put nearly 74 litres in the A6 , regularly get 70-72 in, book says tank is approx 68 litres.....
    2005 Audi TT 1.8T
    Nov 2008
    25
    The petrol station's pump calibration are out they stole your money.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Quote Originally Posted by Theo0000 View Post
    Dont they all!!!!!
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    always fill it when the light comes on as the great heavy cab drinks it in my opinion and dont fancy pushing her anywhere.
    mate of mine had a tt that ran out of fuel with still 25 miles left on the dis regularly
    and it put me off letting them get to low.
    LOTS DONE, LOTS SPENT !!!!
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by 1wheelonly View Post
    I took the chance as I've never let it get below about 40 miles before but there was usually more than 10 litres left in the tank when I filled up so I assumed there was a fair old "idiot" factor built into the remaining range
    colintdi's Avatar
    Jun 2007
    county down
    160
    Not that brave just drove into the petrol station as it went 0. Won't like to risk it
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    ive coasted 30 on vapours in mi old pd130, but the beast has to be nessle'd into the nearest station ASAP lol
    Vehicle wrapping specialist
    NOW SOLD S6 Avant 4.2 V8....ooooo the noise hehe
    NOW SOLD '03 A3 TDi Quatty Sport Mods so far: Aerowipers front & Rear, Type R Sting ariel, 18" RS-TT Alloys, Superchips remap, Eibach Pro Springs -40mm, Bilstein B8 dampers, R32 ARB's Front & Rear, Pipercross panel filter
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    That'll be a national problem from Scotland to Cornwall then
    2005 Audi TT 1.8T
  28. #27
    Oct 2008
    9
    I rather embarrasingly ran out after about 7 miles in my 3.0 Cab. I blame TopGear for Clarkson driving miles on '0' in that big jag!! ;-)
  29. #28
    Barry#1's Avatar
    In The Pit Lane
    Apr 2009
    24
    Never let mine go past 25 miles on the DIS, too scared in case i break something...
  30. #29
    scoTTy's Avatar
    Essex, UK
    1,957
    I went 25 miles past 0 in my B6 S4....which is a lot of fuel in an S4!
    I've now got a new B8 A4 2.0t. It's only been filled up once and it's currently reading 320miles gone and 5 left on the DIS. Lets hope this ones as forgiving as the S4.
    p.s. If you get more than about 1L over the max tank capacity then report the garage as they're ripping you off!!
    MY2010 B8 A4 Avant 2.0TFSI quattro S-line Executive
    Honda CBR1100XX Super Blackbird
    Gone : B6 S4 (AMD stage 3), TT (APR), Golf GTi, CBR600F
  31. #30
    scoTTy's Avatar
    Essex, UK
    1,957
    It went to zero straight away so filled up about 7 miles later.
    Travelled total of 325.1miles
    After : predicted range of 405miles. I only managed to get 60 litres in. This means that that when it showed 0 miles there was at least 1 gallon in there.
    Now I feel like I chickend out early
  32. #31
    AndymacA4's Avatar
    Oct 2008
    154
    Not quite to zero, but I had been driving like a nun to the filling station. I was happily tanking up the A1 yesterday when I noticed I had a range of 25 miles left. I didn't know how far the next garage was, so I dropped to about 60mph on cruise and when filled it showed a range of 550 miles! Never going to do it!
    Fiat Stilo 2.4 Abarth 170bhp and climbing!
