AH FabricationsBadger5
    AndymacA4's Avatar
    Oct 2008
    154
    Pipe Fittings for a 710N valve.
    While I was under my car today unsuccessfully wrestling with the brakes, I thought I'd replace my 710N with a new one I bought a while ago. The bottom connector has been off before as it is now a worm drive jubilee clip, the other two are factory. It has the smallest pipe retainer I have ever seen. It is a small steel clip which covers the vacuum pipe connector. Now, does the vacuum pipe need a clip to retain it? And if so, what do those of you who have replaced it use?
    Many Thanks
    Andy
    Fiat Stilo 2.4 Abarth 170bhp and climbing!
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Ive seen some with some without but I just put a Cable tie around mine, bit fiddly but a "not too tight " precaution!!!
    Dont think it'll hurt not putting one one anyway as its the other 2 pipes you need to make sure are tight..
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    aye good call j7uss, a tie wrap would be perfect and the vac pipes will pull them selves on if snug enough at the end.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    AndymacA4's Avatar
    Oct 2008
    154
    Lovely job, thanks
