Sky InsuranceEM Tuning
Results 1 to 12 of 12
Thread: WILL THESE FIT?
    Dec 2006
    489
    WILL THESE FIT?
    A friend of mine is selling some replica rs4 alloys which he currently has on his mk4 golf - will they fit my B6 A4? I think he said the pcp was 5x100 and 5x112? When looking at alloys what dimensions should I be looking for?
    Also, should the 18'' alloys come with 225 or 235 tyres?
    05 Audi A4 2.0T Quattro
    Black with a BIG wish list!
    Matty A4 TDi Sport
    Dec 2008
    Near Banbury
    45
    as far as i am aware the a4 is 5x112. and the tyres should be no more then 225
    Audi A4 B6 1.9 TDi Sport 180bhp In Dolphin Grey. Kei Force 10 Wheels. VDO Boost Gauge. JE-design, ABT + Vortex Body styling. HID's, AP coilover suspension, turbo back exhaust with twin exit pipes RS4 style The Stealth look is well under way and not far from compleat
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    You need PCD 5x112 offset I think on the B6 is 45 although I think you can go to 35, Tyres can go to 235 or smaller.
    Dec 2006
    489
    great, thank you!
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    yes im running 225s on mine but i think alot of the s-line models and other guys on here run 235s no problem.
    mine do look stretched, 235 would be better
    LOTS DONE, LOTS SPENT !!!!
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    The factory 18's are 8x18 with an offset of 43mm, a lot of the replicas have a 35mm offset which is fine. Tyres should be 235/40/18
    A4 Avant S-Line quattro - Avus Silver/Silver Half Leather *240ps*346nm* - a few choice mods. Now Stared up ;-)
    Dec 2006
    489
    43 - 35 OFFSET - That is a massive difference, what does the offset figure represent and what would be the visual difference between the above dimensions when fitted to the car.. I like the standard look so don't really want to entertain some odd fitting replicas... Or am I getting the wrong end og the stick?
    On my 3rd A4! RS4 next???
    Oct 2005
    Nottingham
    159
    I'm no expert but the offset is the distance between the mating face of the wheel and the centre line, so a wider wheel would need a different offset to give the same fit as standard. Usually a range of offset will fit.
    Also the golf pcd for the studs is smaller than the a4 - so unless the wheels are multi drilled for different stud patterns they won't bolt up.
    you could always offer up one of the fronts to test.
    Chris
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    Quote Originally Posted by AudiSport View Post
    I would hardly say 8mm is massive!!!
    Fitting the rep's would be the same as fitting 8mm spacers to standard wheels.
    Standard 43mm offset..................
    8mm spacer fitted (so 35mm offset)......................
    It's about as far as you can go without looking like you've fitted some wheels from a lorry.
    HTH
    Dec 2006
    489
    Now thats a really nice look - where did you get your spacers (should I find a set of OEM alloys)?
    So the smaller the offset, the more the alloys come out from the car... Hmmmm, sometimes I wish I was more mechanically minded because that doesn't make sense to me!
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    An offset is a negative measurement - so if it wasnt there, the wheels would stick out 43mm (nearly 2 inches) past the arch lets say, so a negative "offset" of 43mm is applied by machining the mating face of the inside of the wheel "hub" so that it sits back under the arch. Does that make sense?
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    It's quite simple really...........
    The 8mm spacers were H&R ones. I'm using MTM 10mm ones now,from QST...
    You'll be fine with the replicas, don't worry about trying to find some OE wheels.
    HTH
