Monster MotorsportEM Tuning
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    Changing foglight bulbs - what's the procedure?
    As per title, how do I access the foglight housing to change the bulbs on a 2003 B6 with standard bumpers & grilles?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    I think you need to jack the car up, or it might be a case of getting the front bumper off, dont quote me on it, but im sure i heard that a while ago....
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    you need to remove the grill that surrounds the fog light by pulling it forward, it just unclips. this will give you access to the fog light assy that is held in place by a couple of torx screws if i remember correctly. remove the light assy to gain access to the rear of the light to replace the bulb...i think, i did mine about two years ago so if any one else can confirm or correct me
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
