Okay, I'm bored of poor braking, I am going to bite the bullet and upgrade my 288mm disc to 312mm discs.
I need a set of caliper carriers (Got these sorted)
Discs and Pads.
I have noticed that many firms list the same pad part number for both 288 and 312 disc application, which makes sense, as I'll be using the same caliper. But which part number!!!
I'm after a set of good quality pads like brembo or feredo. Anyone got correct part numbers? (I tend to use these people for parts
I also need discs, I'm looking at Nitrac cross drilled discs, they should be easy to source.
Finally, will I need a new fitting kit/spring set? - I was advised to replace the spring tensioners on my old Alfa every 2 pad changes as good practice, does this apply to Audi too?
Many Thanks
Andy
Discs and Pads.
Many Thanks
Andy
