    Nov 2008
    remap and leak from rear coolant flandge
    I'm a new to this forum as well as a new driver. I'm driving the B61.8T quattro, planning for a remap. Went to AMD essex for a few times to do my clutch change and oil service and stuffs.
    But i am not sure whether AMD essex or Custom Code do a better remap on my car? Can anyone here tell me the difference, as 3rd gear accleration is not pulling well enough, and i require a contant increase in power.
    Secondly, just did my MOT, although i've pasted it, but report shows Time-belt and there is a leak at the rear coolant flandge, are they immediate problems need to be solved?
    Cheers guys.
    Nov 2008
    just donwer whether anyone can give some help ?
    Uxbridge
    152
    Go to MRC for your remap.
    'Daytona B7 RS4 Saloon - with all the trimmings'
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    timing belt required and a coolant leak? You would be well advised to fix those right away mate, they could kill the engine without even remapping it, which will make the situation even worse.
    If you dont fix them and the timing belt goes then your shiny engine will be a pile of bits and cost around 3000 to replace with a recon unit, untested second hand engines are around 1800 and thats if you can find one.
    These motors are good but the timing belt is not something to ignore as many others have found to their cost. Overheating from coolant leaks could kill it as well if its not checked constantly or gets worse.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    Nov 2008
    cheers mate for that. but is it ok going to any random garage or a better one is more suitable for me?
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Evil's covered it!
    The coolant flange went on mine a while back, I was filling it with water every other week and eventually got worse then it went in for service and they found it was the Flange.
    I wouldnt let anyone work on my motor, if you want cheaper labour price then find a specialist, usually cut labour down by around 60%.
    As for the map, there are loads of companies doing them now and prices vary from 200 to around 550.
    IMO a guy who comes to your house and remaps it is just as good as these bigger companies. Just make sure they have a good reputation, if you dont know their background then give it a miss.
