JMB RetrofitsAH Fabrications
    Aug 2008
    9
    Do you know a good local independent Audi specialist
    HI there,
    i have a 2003 1.9 TDi A4 Avant that will soon need a service. Do you guys know a good local independent Audi specialists around the Eastbourne (East Sussex) area?
    I am getting moisture on the inside of the windscreen after the car has been parked up for sometime (when the weather is cool/cold outside) and fumes in the cabin 65% of the time. Haven't worked out why yet. But will hopefully get the garage to sort these issues.
    Any suggestions would be greatly appreciated as Audi want about 330 for the full monty service.
    Many thanks,
    27,029
    That could be a sign of a hole into the engine bay which would let in condensation moisture, check the firewall for any gaps & get a torch in under the dash & have a quick look.
    I wouldnt suggest QST thats for sure, I'm not far from you so PM me maybe sometime you can pop by me for a quick vagcom check & maybe have a look for you.
    Oct 2006
    83
    try g-werks down in littlehampton either speak to either darren or rob my a4 service was 125 from them
