Car went into what i assume was limp mode today whilst on the motorway. Drove it home ASAP about a mile. The EML was flashing and beeping at me. So i have just ran a VAG-COM scan and the only things it has flagged up is the following. Now the ABS no fault found always shows up, also the secondary air injection has been on before, but i fixed a split pipe and it went away. It however did return about 2 weeks ago, i was going to replace the whole pipe this time.
Any ideas what it could be? Is it just because of the secondary air injection system? I wouldn't have thought that would put it in limp mode? Do i need to get it checked out by a garage?
Address 01: engine
Component: 1.8L R4/5VT 0004
Coding: 11501
Shop #: WSC 63351
WAUZZZ8EZ1A061386 AUZ6Z0A0082872
3 faults found
16795 - Secondary Air Injection System - Incorrect flow detected
P0411 - 35-00 - -
16684 - Shareware version - To decode all DTCS
P0300 - 35-00 - - Please Register/Activate
16685 - Shareware version - To decode all DTCS
P0301 - 35-00 - - Please Register/Activate
Readiness: 0000 0000
Address 03:
ABS/ESP Front D1320
Coding: 04275
Shop #: WSC 06435
No fault found
Address 01: engine
Coding: 11501
Shop #: WSC 63351
3 faults found
P0411 - 35-00 - -
Address 03:
ABS/ESP Front D1320
Coding: 04275
Shop #: WSC 06435
No fault found
