JMB RetrofitsAH Fabrications
Thread: alarm beep
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    alarm beep
    i have set the alarm to beep aswell as flash on setting with vagcom, i am only getting a beep on setting and not on unsetting the alarm, can any one help?
    LOTS DONE, LOTS SPENT !!!!
    A4Ade's Avatar
    Back from the dead
    Jul 2008
    Lancaster
    80
    Quote Originally Posted by 1wheelonly View Post
    As far as I'm aware that's what it's supposed to do - it's the same for mine anyway...
    Ade
    JamesS4cab's Avatar
    Mar 2008
    1,122
    Same as mine on my S4 cab.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    cheers lads,
    i knew the a3's did it on lock and unlock so i thought ours might aswell.
    Oct 2007
    69
    how is this done guys mines only flashes would like it to beep also??
    3.0 V6 Quattro Sport.
    A4Ade's Avatar
    Back from the dead
    Jul 2008
    Lancaster
    80
    Quote Originally Posted by -chris- View Post
    You need VagCom (or similar) which can be found at ross-tech.com. Depending on what car you have and its age the shareware version can do this - then you only need to spend ~15 on a suitable lead. If your car is newer it will cost significantly more. Give us some more info and we can take it from there.
