Volks AutosChris Nott
Results 1 to 10 of 10
    cheekeemonkey's Avatar
    Dec 2007
    125
    A4 Avant - Tailgate closure problems :(
    Hi All
    Recently my tailgate has started playing up
    Basically when I pull it down to close it seems to bounce off the latch rather than closing fully etc.
    I have checked that there are no items that are blocking the locking area and also have greased the latch to see if it was a case of it just needing lubing but...still doesn't seem to work
    More frustrating is that it is sooo inconsistent - can be fine for a few days then wham I'm taking 4 or 5 attempts to close it before it fully catches (usually in the rain too)
    Any ideas as to what I try next or what might be causing this please?
    TIA
    2003 A4 Avant 1.9TDi Quattro Sport
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Mine does the same, its pretty rare but does happen. It doesnt do it enough at the moment for me to even think about looking at it.
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    My A6 recently had exactly the same problem, except it just completely stopped working, none of this try 4 times and its ok. The mechanism inside the hatch was thoroughly cleaned and lubed at the last service and the problem has gone away. I had thought it was the latch assembly and like you had cleaned it all up but the problem was actually the bits hidden inside the hatch.
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
    Dec 2007
    125
    Hmmmm
    Might have to take the tailgate trim off - I had a look before and know there are a few screws near the pull down handles then you just pull to unclip the bottom part but any ideas/experience on how it is fastened near the rear glass - don't want to pull it incase something snaps
    Marc1's Avatar
    Feb 2008
    721
    Mine started doing this too, really annoyed me and ended up trying to close it more and more firmly, which had a complete adverse affect. Try just letting it drop gently with a very slight push when it's about elbow level. It's worked every time since now - touch wood!
    Dec 2007
    125
    I'll try that Marc
    Must admit I did slam it once and I snapped the thumb screws that hold in the warning triangle
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    could be the screws holding the metal loop on the bottom of door itself have loosened and the loop isnt always sitting straight when it tries to enter the latch?
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    Y 14RGE's Avatar
    Mar 2008
    Cornwall
    95
    Yeah, mine does this too when it wants (usually when raining or baby sleeping) although something rattles inside the hatch-loose metal sound ? does anyone know how easy it is to strip down and investigate ?
    Revo'd, Tinted, RS4 Honeycomb Grill, ABT Front bumper, 9 x 19" Bentley Continental Alloys.
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    that'll be the strainer plate behind the loop thats rattling mate, indicating the screws are indeed loose. The rear trim isnt that hard to remove I imagine like most cars just look round for capped off screw points and gently remove all of them and the bits will be all visible, tho you should be able to tighten them without dismantling the trim, just look up into the door lock part on the tailgate and you should see the torx screws, tighten them then adjust the loop with pliers or mole grips then when its closing properly, tighten them fully
    27,114
    also after time if loosened up from constant open/shut/slam etc the bottom loop/plate can move slightly out of alignment, so try adjusting the loop up/down if possible & see if it closes better in certain positions, I cant recall from my S4 if it was adjustable, should be given how bad the lines of the cars are these days, gaps around bodywork seem to change from car to car.
    as already mentioned a good clean of the actual lock mechanism is another one given how much dirt can accumulate after time from the rear area & as its a B6 its obviously few years old now so wouldnt do any harm & could save u few bucks to
