EM TuningAH Fabrications
Results 1 to 7 of 7
    Niknak's Avatar
    Oct 2006
    manchester
    864
    Gear box question
    My gear leaver has stopped returning to the centre of the gate when you take it of gear, any idea why?
    Ian
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    maybe the nylon ball and socket is dry or tight mate, try some oil like 3in1 or similar and with the boot pulled up, drip it into the white plastic ball joint in the centre of the shaft and on the side rails too since your in there - and hopefully that should sort it, I had this prob on the Alfa TDi and that cured it
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    Niknak's Avatar
    Oct 2006
    manchester
    864
    Took up the sleave and it was full bits, so cleaned it off put some lube on and feels much better thanks.
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    ah no probs!
    The foam deadener probably started to break up, I threw mine in the boot when i did the quickshift
    Oct 2005
    Lancashire UK
    202
    Is it easy to get access? May I ask how you did it Niknak?
    2001 - Silver A4 1.9TDi Sport
    Jun 2003
    World of my own
    9,813
    You just prise up the leather gaiter (it's just clipped in) and it's all there.
    Alex Turner
    Niknak's Avatar
    Oct 2006
    manchester
    864
    As Andymac says there are 4 clips at either corner that clip out, just make sure you don't lose any clips.
