Chris NottMonster Motorsport
    May 2003
    Ireland
    52
    Reverse Lights on
    Hi,
    My reverse lights are staying on, regardless of whether I'm in reverse or not. This is even the case when I don't have my lights on. No bulbs were replaced recently, this just started happening. Any ideas?
    Thanks in advance.
    Darren
    jase0851's Avatar
    Oct 2004
    yorks
    778
    do you have vag-com ? i would start there see if there is any fault codes
    EBONY PEARL 2003 1.8T SPORT GMBH 190 AVANT 19" GALLARDO,S S4 SILVER SILK NAPPA HEATED RECARO,S MATT ALI MIRRORS,O.CT INTAKE PIPE, B7 DTM VOTEX SKIRTS, HYPERBOOST HX DIVERTER VALVE, RS4 DOORCARDS+TRIGGERS, AUTO-DIMMING REAR VIEW MIRROR, RS4 BRUSHED ALI TRIM, RS4 START BUTTON, PIPERCROSS PANEL FILTER, RIEGER INFINITY FRONT BUMPER:: NOW REMAP,D TO 240 ISH BHP OMG WHAT A DIFFERENCE
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    the switch that controls the reversing lights is usually fitted to the gearbox and will likely be the problem, it closes its contacts when reverse is selected and so it must have collapsed and shorted inside to put the lights on constantly. Incidentally reverse lights dont only work when the lights are on, they work all the time on all cars.
    Find the switch mounted on the gearbox and unplug it, the lights should go out, showing the switch to be faulty. A replacement cant be expensive, maybe 5 to 15 at a guess, try vagparts.com
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    howdy quattro's Avatar
    Dec 2007
    boston, lincs
    318
    yeah, scots is right, you sure you haven't jumped into a ford sierra by mistake?!? they were always doin it!! more than likely be the switch at fault mate.
    May 2003
    Ireland
    52
    Quote Originally Posted by evilscotsman View Post
    Thanks for all that.
    I'm aware the reverse lights come on whether the lights are on or not, the reason I mentioned the above is that I once had a B5 and the brake lights were staying on whilst the lights were on - turned out to be a dodgy tail light bulb causing it. So it was just to avoid people telling me to check other bulbs.
    But anyway, thanks for the information and I'll try to get to the bottom of it.
