Badger5Volks Autos
Results 1 to 16 of 16
    Rocko's Avatar
    A5 TSFI
    Apr 2007
    N. Ireland
    532
    Black lights - How to...
    Ok heres the "How to.." for doing your lights black like mine. After doing these ones last week Ive upped the difficulty rating to 3 Stars. So only take this one, if you have extreme amounts of patience and you like a bit of butchery! I buggered off before the process was completely finished but you basically reverse the first part and put them back on the car.
    Here goes.
    Ok, first job is to remove the front bumper. Its 3 x 10mm bolts either side of the bumper and two more underneath. You get to the side ones through the splash guards. Get someone with small hands to do this, thats why we have a "Weeballs" (as seen on the right).
    Lights look like this before...
    Once the bumper is off try not to look at the car, its quite a sorry sight.
    Now to remove the lights, you take out the 4 x Torx screws, two on top and two underneath. Excuse the rock fingers, I dont have very big hands either.
    Once free'd, just pop the light connections out as so..
    Hole you leave should look like this and the front looks like....
    So thats the lights removed, now we have to get them ready for baking. Remove the bulbs you can, its been proved that the heat doesnt upset them too much.
    Remove this rubber surround, it just pulls off but dont go mad as you can rip it.
    Top of the light should now look like this...
    During this process, preheat your oven to 100 degress C. Now bosh them in the oven for 1 hour.
    Make tea.
    After an hour or so, doesnt matter if you're 15 minutes over, take them out. Be careful as they are hot and all the little metal bits are fecking roasting! Use oven glves and a Ryan.
    Now, this is the hard part. Go to work on the bonder running round the lights with a butter knife working it into all the gaps and prising the light apart. At this point, its a good idea to get a legend such as myself to help.
    You really need to go to town on the bonder to get a gap created to eventually pull the lights apart. AS I said before, dont attempt this if you dont like butchering your car parts.
    If the bonder cools too much, itll become very difficult to work apart so dont be afraid to chuck them back in the oven for a while. (These ones took 2 hours!, mine took an hour)
    Once you have the plastic cover off the light, you will have the light assembly and the plastic lens cover containing the chrome bit you want to paint. Best way to remove the chrome piece from the plastic to the persuade (gently!!) the thin part to the right of the light out first. Then it will all just pop out. (Thin part on the right hand side of this picture)
    Now you want to get your chrome lens surrounds off. Again they just need a bit of persuasion and they'll pop off no problems.
    Now what I do, is tape the front of these and spray the outsides. Best way to do it is to layer tape on and then cut the excess off.
    Once its been given a few coats of matte black paint and left to dry, reassemble in the reverse order. Put them back in the oven to reseal the bonder, but if you think it needs more sealing then just use normal bonder. Mine didnt, they resealed in the oven. Reverse all the other steps and bingo, dark lights for your A4.
    Not everyones ideal mod or way to do it and please only do it if you have patience, and dont mind hacking into your lights with a knife. And make sure you dont slice your knackers off in the process. That would not be good.
    Since I fecked off before the car was finished, Ive only got photos of my own car.
    So here it is.
    Ranting about Audi Customer Service
    Nov 2006
    liverpool
    703
    Superb guide that rocko, not something ill be doing myself but im sure this guide will help plenty of people.
    nice1
    Rocko's Avatar
    A5 TSFI
    Apr 2007
    N. Ireland
    532
    These ones were an absolute cock to do, but mine were dont quite easily.
    Aug 2007
    68
    Nice Writeup there well done, but you don't have to take the bumper off to remove the headlights. Tempted to try this myself, but haven't plucked up enough courage yet....
    Rocko's Avatar
    A5 TSFI
    Apr 2007
    N. Ireland
    532
    Well thats true, you dont, you can release them from the back and slide them out but we only discovered that an hour into the process.
    Aug 2007
    68
    Doh! keep up the good work mate
    dansansome's Avatar
    Jun 2008
    bournemouth
    165
    being dumb here...b6 headlights did come in a black variant as standard didnt they?
    my cab seems to have black headlights, and i wondered if the previous owner had done it, or if it is possible to get standard "blackout" headlights. cheers
    nice guide btw.
    Rocko's Avatar
    A5 TSFI
    Apr 2007
    N. Ireland
    532
    I think most of the cabs come with the black lights.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Nice one Rocko! Didnt you seriously know you can get your headlights out without taking the bumper off.ha...
    Quite a few people dont though, well ill be having a go fcuk it, why not!!
    Rocko's Avatar
    A5 TSFI
    Apr 2007
    N. Ireland
    532
    Good man, dont be afraid to get really stuck into them!
    Mar 2008
    23
    Quote Originally Posted by Rocko View Post
    how much would you charge to do mine?
    Rocko's Avatar
    A5 TSFI
    Apr 2007
    N. Ireland
    532
    Since Im in Northern Ireland, 5.2 million pounds.
    Each.
    Aug 2006
    157
    bargain !
    good write up dude
    Rocko's Avatar
    A5 TSFI
    Apr 2007
    N. Ireland
    532
    Thanks very much.
    If I do some other stuff Ill make another one.
    andyccr's Avatar
    2003 1.8T Sport Ebony Black A4 Cabriolet
    Jan 2007
    Chelmsford, Essex
    440
    Just want to say that on a cabriolet you can get the cluster off without removing the bumper
    B6 1.8T Sport Cabriolet - Ebony Black & Red Sports Leather-19" Sportec Mono10s-Bootlip spoiler-One touch roof module-Green Cotton filter-Forge 007 - 2007 rear lamps-2007 OEM interior dimming compass mirror-OEM S4 heated, elec folding, dimming aluminium door mirrors-2007 RS4 cabriolet exhaust-2007 RS4 Carbon trim-2007 RS4 starter button-2007 RS4 inner door handles- A4 DTM carbon front splitter
    1994 UK MX5 in rare Laguna Blue
    2003 Yamaha R1 (5PW) Tech Silver - not standard !
    Rocko's Avatar
    A5 TSFI
    Apr 2007
    N. Ireland
    532
    You can do it on the saloon too but we didnt find that out until the bumper was off already.
