Volks AutosMonster Motorsport
Thread: whistling nose
    stevey_boy's Avatar
    May 2008
    35
    whistling nose
    Recently ive noticed a whistling noise on accelleration at about 2k revs,is this normal or mayb sumthing wrong with the turbo?
    btw its a 02 1.9 tdi A4
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    dont you normally hear the turbo whistle? tdi's are louder than 1.8t's and i can hear mine whistle up at 2k - though now i have a cai you just hear the rushing sound of the air over the whistle.
    Have you had the car long? If so then maybe you have a boost or air leak, check all the hoses going to the turbo etc.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    26,774
    Whistle on audi diesel turbo's is normal, if its extraordinarily loud could be sign of wear, whats car specs, age, mapped etc etc?
    Has it lost any power at all at 2krpm & above?
    stevey_boy's Avatar
    May 2008
    35
    no hasnt lost any power! the car is 6 years old with 98k on the clock and been remapped to 160bhp
    26,774
    well sure you just havnt been de-tuned to the noise, does happen as per my TDI makes a fairly loud whistle on turbo but I dont worry about it as Simon@amd said its quite normal & only questionable if loss of power or any engine changes etc, my S3 DV was the same with the CDA airbox, just got used to & worked 100% fella.
