EM TuningMonster Motorsport
    Feb 2008
    Injector Problems Help!
    Ive a A4 TDI 130 , and I've put in dirty diesel. Didn't start last week so sending it to garage the fuel has been drained ,filter changed .Second hand injector pump and second hand Injectors all replaced. Now It runs great but when idle the whole car shakes and doesnt seem to tic over well. Has anyone got this done before and has anyone got any advice Cheers..
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    were they oem tdi 130 injectors? or off a 110 or summat? Is the cold start smoke very reduced and on hard acceleration?
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    Feb 2008
    I don't know if they where off a 110 never even thought..doesn't look like theres as much smoke coming out as before
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    ah that may be the problem then, theyre too small and not enough fuel is getting injected?
    You should check the part numbers against your originals and get the proper ones if theyre wrong
