I think the sidelights and fogs or just sidelights or dips + fogs depending on coding value, there should be a thread on rosstech showing the options on our cars.
You can i think choose which lighting you want - right down to dash lights, red needles only, red + moonlight numbers, numbers only etc etc. Only fully selectable from 2002 onwards I reckon but could be wrong about that
You also (as i mentioned earlier) have to set the car's region to somewhere where DRL's are compulsory, canada and sweden being 2, there may be others...this can affect the alarm beep options too as some country codes beep, some dont, but its not hard to set how you want it if you read the coding instructions carefully. Unfortunately for some its done in Binary (base-2) arithmetic. Heres a quick & simple rundown on binary coding (written by me not stolen lol)
Binary uses digits like our normal base-10 system.
(base 10 obviously has units, 10's 100's, thousands etc, and as you know when a digit gets to 9 it "spills over" as a 1 into the next column, so 9 becomes 10)
Binary digits can only be 1 or 0, when they increase above 1 they spill over into the next column as a 1. Each digit position is called a "bit" - and each bit from right to left (yes right to left) represents a fixed decimal value.
They number binary bit columns from 0, as in bit0, bit1, bit2, bit3 etc so for 4 bits they are numbered only to bit 3:
Bit# 3 2 1 0
Value 8 4 2 1
So:
0001 = 1
0010 = 2
0011 = 3
0100 = 4
0101 = 5
0110 = 6
0111 = 7
1000 = 8
1001 = 9
etc etc - from the right to left the bit value just doubles, i.e. 1,2,4,8 so any number is made up by putting a 1 in the column for each value that adds up to the one you want, so 0110 = 0x8,1x4,1x2,0x1 which = 0 + 4 + 2 + 0 which = 4 + 2 which = 6
If a vagcom coding value for some area like "comfort electronics - lights" is say 6 then that would be 0110 in binary, so if enabling some feature meant setting bit3 to 1 - then your new binary would be 1110 = 8+4+2 = 14 decimal, you would enter "14" into the coding value field, and click "do" to enter the new number.
