AH FabricationsJMB Retrofits
Results 1 to 8 of 8
    henry74's Avatar
    Feb 2007
    Verwood, Dorset
    115
    Help! I'm Melting!
    Guys - please can anyone help save me from a summer of sweatiness and frustration?!? I thought i'd be able to get by without my aircon working but this heat is doing my nut! To recap, Kwik-Fit have regassed but still no go and 1 air-con specialist has said new compressor @ 470! Does anyone have Vagcom in the Bournemouth area who would be willing to run me a diagnostics check in return for a small fee? Then hopefully i might have enough info with which to make a decision as to what to do next!
    Many thanks
    Richard
    russgt's Avatar
    Mar 2007
    60
    My aircon gave up shortly after a regas but a mate assured me that the pressure switch was at fault..... and it sure was now its running perfect
    The Near side light had to be removed to gain access to the pressure switch which is located on the right hand side of the aircon rad.
    The switch was around 45 if I remember correctly. HTH
    B6 1.9 TDI 130 Sport Avant
    henry74's Avatar
    Feb 2007
    Verwood, Dorset
    115
    The pressure switch has been mentioned, which i'm hoping would show a fault code! Does any gas escape when you change the switch?
    technics100's Avatar
    Feb 2004
    Co Antrim
    773
    The switch also went on my last A4. No gas escapes when changing, it just unscrews. It will show a code in vag-com - G65 pressure switch. Hope that fixes it..
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    How did the Air con Specialists diagnose a compressor?
    What tests did they do...
    henry74's Avatar
    Feb 2007
    Verwood, Dorset
    115
    J7USS
    They jacked up the front of the car (offside), started her up, whacked the air con on and connected some hoses and a gauge to the connections by the air intake! Hence my desire for a second opinion! Want to find a definite cause rather than process of elimination as funds are tighter than a duck's bum!
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by henry74 View Post
    J7USS
    Welcome to parenthood ....
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    J7USS
    How my air con spec did it was, Bypass everything and wnet straight to the Compressor and it worked fine, Air was Ice Cold, soon as we reconnected, it didnt work. So least we knew it wasnt the compressor and saved me buying a New one for Fcuk all!!thank God.
    Take it to an Air con Specialist (different one of course) and ask him to bypass and wire the compressor directly, he should know what you are talking about and test it that way. If he says he cant do it then he just cant be bothered.
    Try it mate
