Results 1 to 33 of 33
Thread: Brake upgrades
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Brake upgrades
    Bear with me here, because I know absolutely nothing about this generation of A4...
    A mate of mine has an 03 130 PD TDI A4...and complains about the brakes.
    I don't know what size they are standard...but is there a reasonably cheap upgrade out there?
    The sort of bigger disc/calliper carrier upgrade other models get away with?
    Or is it upgraded pads or a big brake kit as the two choices?
    Any info welcomed...thanks.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    Aug 2004
    Aberdeenshire
    740
    I'd agree with the brakes being rubbish. Our car is the same except a 2004 model. When it needs disks I'll be looking at an upgrade. probably not far off as the disks have a fair lip on them after only 35k
    S4 brakes are a common choice. No idea of cost and don't know if they fit with 17" wheels.
    Not sure of parts required but it'll be at least disks, caliper carriers and calipers. I think the bigger splash guards are needed. Would probably be worth putting on some Goodridge lines at the same time.
    stoakseya4's Avatar
    Aug 2005
    Kent, UK
    1,227
    There's been a few threads on brakes recently. Obviously a popular mod at the moment...
    The S4 brake upgrade seems to be relatively easy, so long as the car has min 18" wheels. A 'kit' has been advertised on eBay recently for 350 + labour to fit, which I would guess at being circa 3hrs? So at a local garage at say 50/hr, that would c500 fitted.
    Brembo do a kit for about 800 supply only.
    You can also buy Porsche 996 calipers and with some carriers made up to use them, apparently does the trick too. I'm thinking about the S4 option...
    Not sure of the standard size, but would think they're c280mm dia. The S4's discs are 345mm...
    Hope that helps, although others know ALOT more about this subject than I !
    1998 S4 Widebody Saloon Track Car
    2006 320d SE Touring - Ze Fuhrer's Wagon
    2001 B5 RS4 510bhp & 508ft lbs SOLD
    1.9TDI (130) Sport -Black-Revo - Mrs Stoakseya4's mota - SOLD
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    I put B5 S4 brakes on my 130 tdi A4.
    323/30mm discs and twin piston calipers.A massive improvement over the standard ones.Straight fit and can be had for less than 150 for the lot.
    Heres mine
    andyccr's Avatar
    2003 1.8T Sport Ebony Black A4 Cabriolet
    Jan 2007
    Chelmsford, Essex
    440
    Whos that then Stoaksey ?!?!!
    B6 1.8T Sport Cabriolet - Ebony Black & Red Sports Leather-19" Sportec Mono10s-Bootlip spoiler-One touch roof module-Green Cotton filter-Forge 007 - 2007 rear lamps-2007 OEM interior dimming compass mirror-OEM S4 heated, elec folding, dimming aluminium door mirrors-2007 RS4 cabriolet exhaust-2007 RS4 Carbon trim-2007 RS4 starter button-2007 RS4 inner door handles- A4 DTM carbon front splitter
    1994 UK MX5 in rare Laguna Blue
    2003 Yamaha R1 (5PW) Tech Silver - not standard !
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by Macduff View Post
    Is this just a 130 problem? I have a 2.5 TDi 180 and would say the brakes are very good.
    stoakseya4's Avatar
    Aug 2005
    Kent, UK
    1,227
    Play nice now Andy !!
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    My 130tdi had 288mm front discs and the v6 tdi had 312mm.Both use the same caliper though.
    phil1978's Avatar
    Dec 2004
    Home of the white stilleto
    183
    You can use the caliper carrier from the 3.0L petrol or the 2.5tdi. This moves the caliper further out allowing the bigger disc, 312mm, from the aforementioned cars.
    This is probably the cheapest route which has a good increase in stopping ability.
    I weighed up the brembo, S4 and this method. This was the best solution for what I needed. Its not like the 1.9 is gonna break any records . . . . . So anything more than that was a waste of money.
    My two penny worth anyway.
    I think it cost 230 all in for discs, pads new carriers and splash shields.
    07 A4 Cab 2.0T FSI S-Line
    06 Suzuki GSXR750 K6
    Gone But Not Forgotten:
    04 A4 Tdi Quattro Sport
    03 Golf GTI T
    If in doubt go flat out
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by phil1978 View Post
    Which is more expensive than the b5 S4 ones and nowhere near as good.
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    My Sport 163 has big brakes, not sure if they are uprated or original, but they are ferocious! Probably the 312mm standard fit for the car but they are incredible.
    Might be a cheaper alternative to the S4 ones for you? Dunno how much Sport brakes are second hand tho, maybe someone can advise?
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
    phil1978's Avatar
    Dec 2004
    183
    Quote Originally Posted by james0808 View Post
    Is that including new Audi discs and pads ????
    03 Golf GTI T
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    No.
    b5 S4 calipers can be had for as little as 50.I got some new grooved discs for 99 delivered and Mintex extreme pads for 40 delivered.
    I replaced the oem Audi ones with these and the difference was amazing.
    Not bad for 190 and better than new Audi discs and pads.
    312mm are a bit better than 288mm but are a waste of money as an upgrade when compared to these.
    jase0851's Avatar
    Oct 2004
    yorks
    782
    dont the s4 calipers from a b5 fit straight onto the 312 set up, so its just a case of fit the calipers then new discs and pads
    EBONY PEARL 2003 1.8T SPORT GMBH 190 AVANT 19" GALLARDO,S S4 SILVER SILK NAPPA HEATED RECARO,S MATT ALI MIRRORS,O.CT INTAKE PIPE, B7 DTM VOTEX SKIRTS, HYPERBOOST HX DIVERTER VALVE, RS4 DOORCARDS+TRIGGERS, AUTO-DIMMING REAR VIEW MIRROR, RS4 BRUSHED ALI TRIM, RS4 START BUTTON, PIPERCROSS PANEL FILTER, RIEGER INFINITY FRONT BUMPER:: NOW REMAP,D TO 240 ISH BHP OMG WHAT A DIFFERENCE
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by jase0851 View Post
    I dont know about that.
    There is a big difference in the width of the discs.
    jase0851's Avatar
    Oct 2004
    yorks
    782
    oh right just thought id ask
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    It might work,i dont know.
    To be honest though you would be better off with the bigger disc.
    jase0851's Avatar
    Oct 2004
    yorks
    782
    so what did you buy when you upgaded your brakes then james ? s4 calipers, s4 discs, s4 pads
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    I got the whole front set up including splashguards delivered for 120.Used them for a bit but wanted some grooved discs and better pads so changed them.
    I tried upgrading to 312mm from 288mm on my golf years ago and they was better but not by much so didnt bother wasting my money this time and went straight for the S4 ones.
    jase0851's Avatar
    Oct 2004
    yorks
    782
    did you have to use different caliper mountings to fit the bigger discs or did the set come with them.i have 312 on mine from the factory but i think they are quite weak to be honest
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    I didnt think the 312mm was that good at stopping my golf.I fitted R32 to that and they are very good.
    I got both twin pot calipers,caliper mounting brackets,splashguards,very good discs and pads,all the flexi pipes(dont need them as the original ones will fit straight onto the S4 calipers) evan all the bolts.
    Look very good with a bit of paint too.Visual and performance mod in one.
    stoakseya4's Avatar
    Aug 2005
    Kent, UK
    1,227
    Do B5 RS4 brakes fit ?
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by stoakseya4 View Post
    Not a direct fit like the S4 but anything is possible if you have the time and money.
    duane's Avatar
    May 2004
    uk
    142
    Heres mine
    I've just bought some B5 RS4 brakes to upgrade my S4. I was thinking about putting my S4 brakes on the wifes TDI. So you are saying the B5 S4 brakes bolt straight on to the B6 A4 TDI i wont need anything else at all?
    B5 S4 Kingfisher Blue.
    B6 A4 Atlas Grey 1.9 TDI Quattro Sport.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    [QUOTE=duane;544997]I've just bought some B5 RS4 brakes to upgrade my S4. I was thinking about putting my S4 brakes on the wifes TDI. So you are saying the B5 S4 brakes bolt straight on to the B6 A4 TDI i wont need anything else at all?
    Thats right,b5 and b6 S4 will be a straight fit on a b6 tdi.
    NOLOGY's Avatar
    AUDI OWNER
    Feb 2008
    Cyprus
    99
    they will also fit my b6 a4 cabrio?
  28. #27
    Aug 2008
    hi, i have 17" wheels on a 2.0 a4 b6...whats the best audi parts upgrade for this and what will i need?
    cheers
  29. #28
    Neil_S's Avatar
    Jan 2006
    Hampshire, UK
    248
    B6 S4 upgrade, well recommended. Put mine on a few weeks back after refurbing some second hand S4 calipers
  30. #29
    Mar 2008
    Dorset
    13,856
    Those calipers look the business Neil
  31. #30
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by eg0u4106 View Post
    cheers
    My understanding is that you can put on 312mm disks but not S4 (345mm) unless you go to 18" wheels minimum. You'll need new caliper carriers and splashguards in addition to disks. VAGParts have the caliper carriers and probably the splashguards.
    I have no idea what size disks the 2.0 comes with as standard. It may be 288 which is that same as my TDi.
  32. #31
    Neil_S's Avatar
    Jan 2006
    Hampshire, UK
    248
    Thumbs up
    Yes, I'm rather chuffed with them.
    From this...
    via this...
    to this...
    With a little help from Bilt Hamber Deox-C and a Dremel
  33. #32
    jcb
    Sep 2005
    uk
    4,077
    get some 18" wheels and bolt on B5 RS4 discs and calipers
    you can pick up a full set on eBay for around 150-200
  34. #33
    M22_PRE's Avatar
    A4 autovogue style
    Sep 2007
    North West
    124
    what would hve to be changed to fit the b5 rs4 calipers and discs to a 1.9 tdi that would not need to be changed if i were to fit just the b5 s4 callipers and discs???
    Won best Audi in the show n shine at GTI international 2008 (saturday)
