Chris NottJMB Retrofits
Results 1 to 11 of 11
    T0m
    Sep 2007
    Lichfield
    458
    Changing bulb on rear light cluster A4 Avant
    How do you go about doing it...ive had a look and looks like you have to take off quite a bit of trim is this correct?
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    Nope - just inside the tailgate there's a round section about the size of a 50p coin, pop that out and there's a screw hidden behind it. Remove that - careful not to drop it! - and you can then get the entire light cluster off and replace the bulb.
    Replacement is the opposite procedure.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    T0m
    Sep 2007
    Lichfield
    458
    thanks for that mate ;-)
    Jun 2003
    World of my own
    9,813
    Also you need to ease the light cluster out sideways, but don't wrench it off as theres a locating pin on the back (towards the front of the car). I use a slim piece of metal covered in gaffer tape to slide down between the light and the bodywork in order to ease it out.
    Alex Turner
    coyote's Avatar
    Dec 2007
    213
    PetrolDave I think you are over-exaggerating your size . The round cap on my Avant is closer to the size of a 5p coin.
    The screw also had a bolthead so either use a magnetic screwdriver or a socket to unscrew it and as stated be careful as if you do drop it a lot of the trim will have to come off to find it.
    Or as stated in the manual take it to the stealers
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    Quote Originally Posted by coyote View Post
    Me?????
    I wrote from memory while at work...
    Jun 2003
    World of my own
    9,813
    The screw shouldn't drop out as it's "locked" to the bodywork.
    Alex Turner
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    My grey cover is about the size of a 50p!
    coyote's Avatar
    Dec 2007
    213
    Looks like they must be different for saloons and avants. My Avants bolts are not 'locked' just fiddly so I bought some spares.
    Photo shows spare bolts and cap (and a 5p)
    Mr_Sixx's Avatar
    Stationary
    Aug 2007
    In the sticks of Derbys & Notts
    169
    PetrolDave is spot on with the 50p cap size - mine is the same, had them in bits yesterday.
    Maybe its different for B6/B7 and saloon/avants?
    Either way, dont drop the screws coz you will never find them.
    2012 A3 Tdi 170 S Line Black Edition
    Apr 2008
    north east scotland
    Quote Originally Posted by PetrolDave View Post
    couldn't agree more.did this the other day and dropped the screw making a 10 minute job take 2 hours!just make sure the screwdriver is well magnetized,take your time and it's pretty straighforward.
    kip
