    Oct 2007
    Yorkshire
    changing the dash lights on A4
    Hi all,
    some of my dashbulb lights are playing up, especially the ones which light up the headlight switch on/off dial.
    Do I need a special tool to open up the dial so I can get at the bulbs? The whole thing seems very easy to scratch so i want to be careful i dont mess this up.
    Are there any insyructions I can find anywhere?
    Nov 2006
    liverpool
    703
    same here, mine need replacing in the on-off headlight switch. will be interested to see other peoples replies
    jegs's Avatar
    Oct 2005
    United Kingdom
    Hi
    The headlight switch is a complete unit which you twist and pull out so you get a new unit from your local dealer. Will try and find a diagram later to show how to remove the switch
    HTH
    jase0851's Avatar
    Oct 2004
    yorks
    782
    turn the switch to the left about 10 degrees push it in then turn it to the right 90 degrees
    the bit that turns the lights on
    EBONY PEARL 2003 1.8T SPORT GMBH 190 AVANT 19" GALLARDO,S S4 SILVER SILK NAPPA HEATED RECARO,S MATT ALI MIRRORS,O.CT INTAKE PIPE, B7 DTM VOTEX SKIRTS, HYPERBOOST HX DIVERTER VALVE, RS4 DOORCARDS+TRIGGERS, AUTO-DIMMING REAR VIEW MIRROR, RS4 BRUSHED ALI TRIM, RS4 START BUTTON, PIPERCROSS PANEL FILTER, RIEGER INFINITY FRONT BUMPER:: NOW REMAP,D TO 240 ISH BHP OMG WHAT A DIFFERENCE
