Monster MotorsportEM Tuning
Results 1 to 7 of 7
Thread: where is ...
    baynesey's Avatar
    well you better unsell them, sharpish!
    Mar 2007
    Stevenage, Herts
    194
    where is ...
    the plug so I can plug in my new VAG-COM Cable for my B6 Avant??
    2003 2.0 FSI SE A4 Avant
    Nov 2006
    liverpool
    703
    under the steering wheel rack i think mate
    Aug 2007
    68
    Under the steering wheel column slighty to the right handside, look and you shall find... (hopefully)
    baynesey's Avatar
    Mar 2007
    Stevenage, Herts
    194
    cheers peeps!
    Aug 2007
    68
    Also look here for a good starting guide:
    http://www.audizine.com/forum/showthread.php?t=158766
    baynesey's Avatar
    Mar 2007
    Stevenage, Herts
    194
    Sorted!
    This is my read out ...
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8E - Audi A4 B6
    Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
    Address 01 -------------------------------------------------------
    Controller: 8E1 910 018
    Component: 2.0L R4/4V FSI G 0020
    Coding: 0000000
    Shop #: WSC 63251
    8E0907807 A NOX 0304040102 002 3205
    4 Faults Found:
    17440 - Sensor for Nox (G295): Signal too High
    P1032 - 001 - Upper Limit Exceeded
    16706 - Engine Speed Sensor (G28): No Signal
    P0322 - 004 - No Signal/Communication - Intermittent
    16705 - Engine Speed Sensor (G28): Implausible Signal
    P0321 - 008 - Implausible Signal - Intermittent
    Readiness: 0000 0000
    Address 03 -------------------------------------------------------
    Controller: 8E0 614 517
    Component: ABS/ESP front 3429
    Coding: 04275
    Shop #: WSC 06435
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
    35-00 - -
    Address 08 -------------------------------------------------------
    Controller: 8E0 820 043 AC
    Component: A4 Klimaautomat 1219
    Coding: 00000
    Shop #: WSC 63251
    No fault code found.
    Address 09 -------------------------------------------------------
    Controller: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00011
    Shop #: WSC 63251
    Skipping Address 15-Airbags
    Address 16 -------------------------------------------------------
    Controller: 8E0 953 549 N
    Component: Lenksulenmodul 0308
    Coding: 00042
    Shop #: WSC 63251
    Address 17 -------------------------------------------------------
    Controller: 8E0 920 950 K
    Component: KOMBI+WEGFAHRS. RB4 D36
    Coding: 00400
    Shop #: WSC 01234
    WAUZZZ8E94A030208 AUZ6Z0C0132760
    Address 45 -------------------------------------------------------
    Controller: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    Address 46 -------------------------------------------------------
    Controller: 8E0 959 433 BC
    Component: Komfortgert T3B 1311
    Coding: 07115
    Shop #: WSC 63251
    3 Faults Found:
    01616 - Signal Wire to Interior Monitor
    49-10 - No Communications - Intermittent
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01334 - Door Control Module: Rear Right (J398)
    80-10 - Single-Wire Operation - Intermittent
    Address 55 -------------------------------------------------------
    Controller: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00060
    Shop #: WSC 63251
    Address 56 -------------------------------------------------------
    Controller: 8E0 035 195 P
    Component: symphony II NP2 0152
    Coding: 01001
    Shop #: WSC 00652
    End -------------------------------------------------------
    I'm aware of my NOx issue, part on the way .. but a little concerned about the steering angle, the ESP light is constantly on ... coincides with me breaking down as I havent started the car in over a week
    jase0851's Avatar
    Oct 2004
    yorks
    782
    looks like ya need a nox and engine speed sensor
    EBONY PEARL 2003 1.8T SPORT GMBH 190 AVANT 19" GALLARDO,S S4 SILVER SILK NAPPA HEATED RECARO,S MATT ALI MIRRORS,O.CT INTAKE PIPE, B7 DTM VOTEX SKIRTS, HYPERBOOST HX DIVERTER VALVE, RS4 DOORCARDS+TRIGGERS, AUTO-DIMMING REAR VIEW MIRROR, RS4 BRUSHED ALI TRIM, RS4 START BUTTON, PIPERCROSS PANEL FILTER, RIEGER INFINITY FRONT BUMPER:: NOW REMAP,D TO 240 ISH BHP OMG WHAT A DIFFERENCE
