Chris NottSky Insurance
Page 1 of 2 12 LastLast
Results 1 to 40 of 47
    zeratul's Avatar
    Nov 2007
    Worcestershire
    178
    Question VAGCOM - Why should I get one?
    What are the advantages of getting VAGCOM?
    Will I just be able to use it to diagnose a problem when I eventually get one or is there some fun stuff I can change?
    Is it only going to cost me the price of the lead as the software is a free download?
    Cars: 02 2.5 diesel Allroad / 04 1.8T Cab
    Many thanks
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    The Free download is only limited though but if that doesnt bother you then yeah go for it. Ive been toyin with the Idea but I know what Ill be like, Ill be forever plugging it in if I get a tiny Flutter!!
    Nov 2006
    liverpool
    703
    what kinda options can u change and how much r vagcoms?
    Sep 2007
    Glasgow
    15
    See here mate: http://www.ross-tech.com/products.html
    I'm getting one myself soon. Glad I got a mate in the states who can buy it and send it across the pond saving me import taxes.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Roach - Come on then, dont be tight, get a Group buy going!!
    How much??
    JamesS4cab's Avatar
    Mar 2008
    1,091
    So to quantify, I need to download the free software, and then buy the lead from fleabay and thats it??
    zeratul's Avatar
    Nov 2007
    Worcestershire
    178
    Yup - Lead is going to be about Ł20 at the most but the free software version is limited...
    How Limited is the free version then everyone? We're not experts - do we need the full version or is the free/limited version not worth getting as you can't do much with it?
    Defratos's Avatar
    You’re Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    What? only Ł20 for the lead? are you sure? When I got mine a few years back it was closer to $100 and something, so like Ł60-ish pounds. Surly it couldn't have gone down by that much in price?
    As for how useful is it, for me I used it many many times an it saved me a lot of money, considering most of my problems were small errors that could be easily fixed. The main reason I got it as well was to stop Audi from charging me Ł50 each time just for them to tell me what the problem is, so now I print out the problem and see if I can fix it myself. If not then just give Audi my Vag-com read out and show them what the problem is (which is already Ł50 cheaper) so I think well worth the investment, especially if you're thinking of keeping your car for several years.
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    zeratul's Avatar
    Nov 2007
    Worcestershire
    178
    Quote Originally Posted by Defratos View Post
    Trouble is - I can see our Audi dealer say that they would need to do a test for themselves! and so still charge!
    zeratul's Avatar
    Nov 2007
    Worcestershire
    178
    Just had a quick look.
    Found this and this. Are these going to be any good or am I looking at the wrong type?
    JamesS4cab's Avatar
    Mar 2008
    1,091
    Quote Originally Posted by zeratul View Post
    You can get these on fleabay for much cheaper than that!
    Do a search for VAGCOM and......... bingo!
    Defratos's Avatar
    May 2004
    2,230
    Well I haven't had that problem before, you can even get the Audi man to sit in the car while u do the diagnostic, that should be sufficient for them to accept the read out, unless they're being absolute Tits about it, in which case I'll take it to a different Audi dealership
    Audi S3-BAM
    andyccr's Avatar
    2003 1.8T Sport Ebony Black A4 Cabriolet
    Jan 2007
    Chelmsford, Essex
    440
    It sometimes make the Audi / Seat / Skoda dealers look at you funny. When I had a problem with the factory dump valve on my Octy vRS, I walked in with a printout of the fault codes and a load of info off of the forums about the fault. I even had the TSB (Technical service bulletin) showing them the uprated part number.
    Without any hesitation they ordered the parts under warranty for me and booked the car in for a week later.
    I use VAGCOM for other stuff too... Like when I fit induction kits and forget to plug the MAF back in !! Brings up the 'CEL' (Check engine light), and needs a dealer reset. Also the same on Golfs etc if you forget to turn the passenger airbag off before removing the glovebox, it brings on the airbag light, which can only be 'reset' with VAGCOM.
    All I would say is that VAGCOM can be very indepth, its ok for running fault checks etc, but unless you understand it fully then you could have major problem if you changed any of the coding WITHOUT proper understanding !!
    So, if you want to check for fault codes etc and check 'stuff' then I'd thoroughly recommend it.
    If computers baffle you, or you are not that technically minded then I would say stay well clear. There is normally enough people somewhere to close to you that will have a copy and can help you out for a couple of beers
    Andy
    B6 1.8T Sport Cabriolet - Ebony Black & Red Sports Leather-19" Sportec Mono10s-Bootlip spoiler-One touch roof module-Green Cotton filter-Forge 007 - 2007 rear lamps-2007 OEM interior dimming compass mirror-OEM S4 heated, elec folding, dimming aluminium door mirrors-2007 RS4 cabriolet exhaust-2007 RS4 Carbon trim-2007 RS4 starter button-2007 RS4 inner door handles- A4 DTM carbon front splitter
    1994 UK MX5 in rare Laguna Blue
    2003 Yamaha R1 (5PW) Tech Silver - not standard !
    JamesS4cab's Avatar
    Mar 2008
    1,091
    Quote Originally Posted by andyccr View Post
    Does that include your MSN buddies.....
    May 2007
    Chorley, Lancs
    770
    What version of VAG-COM do I need to programme up my OEM Bluetooth installation to the RNS-e in my 2003 A4 2.5 TDi Q sport ?
    Is a special VAG-COM cable required, or will the Ł15 cables you get on E-Bay be OK to do the job ?
    Sep 2007
    59
    I need to get one of these. Thankfully I'm American, and I can get this shipped to my mailbox on the base. Much cheaper.
    Niknak's Avatar
    Oct 2006
    manchester
    864
    Sandspeed, fancy ordering me one as well?
    Ian
    jase0851's Avatar
    Oct 2004
    yorks
    778
    Quote Originally Posted by JohnboyC View Post
    409-1 version will do what you want programming wise. you can either pay 250 for the lead which is activated or buy an ebay lead the pay for a license which is 50 quid
    EBONY PEARL 2003 1.8T SPORT GMBH 190 AVANT 19" GALLARDO,S S4 SILVER SILK NAPPA HEATED RECARO,S MATT ALI MIRRORS,O.CT INTAKE PIPE, B7 DTM VOTEX SKIRTS, HYPERBOOST HX DIVERTER VALVE, RS4 DOORCARDS+TRIGGERS, AUTO-DIMMING REAR VIEW MIRROR, RS4 BRUSHED ALI TRIM, RS4 START BUTTON, PIPERCROSS PANEL FILTER, RIEGER INFINITY FRONT BUMPER:: NOW REMAP,D TO 240 ISH BHP OMG WHAT A DIFFERENCE
    iyrix's Avatar
    Mar 2010
    427
    Quote Originally Posted by jase0851 View Post
    Hi, just been going through this and im really interested in getting a VAGCOM now. If i get the lead and software from ebay, do i then buy the licence from Roos Tech?
    I want to use it for making changes (like door lock), reading faults etc.
    Graham
    simon.m's Avatar
    Oct 2009
    2,746
    will VAGCOM show up if i have a faulty injector if so any one got one near thanet before i can buy one.
    j033y's Avatar
    200
    I have an eBay one, use it on my Mk4 Golf. The lead was about Ł10 and software free too download. The software however is restricted on third party leads, you can't do everything. However, there are ways around this.
    Not sure if the eBay ones run on CAN cars, not even sure what a CAN is, i could be wrong?!?!
    The only downside of the eBay ones apart from the limited software access, unless you use a way round, or pay for a licence, is they can be dodgy, they can last years or die in a matter of minutes, they are cheap, very cheaply made. also many issues with conflicts with computers that a genuine lead does not have. Plus the freeware software presumes your using a COM port not USB, so you need drivers for that.
    But for what i have used it for; fault diagnosis, clear codes, programming beeps, door locking modes, allsorts, mine worked a treat.
    Like i said, i am unsure whether it will work as well on my new A4 (when i get it) as i have not fully read up on this CAN system, i think the Golf uses a slightly older system.
    But the software is freeware, but it realises when an unlicenced lead (eBay special) is using it, and disables a lot of options, there are (*cough*cracks out there *cough*) ways round it.
    If you buy a fully licenced lead from Ross-Tech they are about $400 i think, and are guaranteed, brilliant customer care etc etc, but there are lots of versions dependant on newness of cars you'll see things like HEX & CAN & BUS!!
    Another fun thing i did on my car was calculate the BHP using VAGCOM, and did a few fancy graphs of road speed BHP etc.
    Its fun
    Aug 2009
    Durham
    110
    there seams to be different codes/cables how do you know which one is compatible and which off the ebay cables would you recommend.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    Quote Originally Posted by choimaloy View Post
    NONE! the ebay ones in my experience are a waist of time and money, very restricted, if you get it to work, no support and youll only endup forking out more money to get a genuine one, therefore get a genuine one first.
    i went down the route of copies first, couldnt justify to myself 250 quid for a lead etc but after commiting to buying a genuine in the end, found that the support and usage was alot better and have more or less covered my cost of lead back already by helping others out with it for beer tokens.
    a genuine one also gives you the freedom to use on alot more vehicles.
    LOTS DONE, LOTS SPENT !!!!
    26,776
    I couldnt say it any better, it will work on all cars new & old, updates will be possible where as ebays are stuck on a certain level & alot of reports of duds or go wrong almost immediately, you wont get support for any ebay lead, also if its not the older interface which is on version 409 backwards then you wont get an offical license for it at all, so yeah there are many plus points to genuine & also negatives, but most people learn there lesson sooner or later, you just cant beat genuine ones.
    sebhar70's Avatar
    Apr 2009
    South London
    200
    Hi NHN,
    Just to say that you done your best to try and arrange a decent price for a group offer, I was all for it but it seemed that Simon was probably tired and fed-up with the whole thing considering his personal trials and tribulations. It might be an idea to arrange a group buy on this forum I dont know.
    iyrix's Avatar
    Mar 2010
    427
    Thanks for all the help guys. Can someone just confirm that this is the right part for my car? Is there anywhere in the UK i should order from?
    http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM
    Graham
  28. #27
    26,776
    Quote Originally Posted by sebhar70 View Post
    Hi NHN,
    TBH mate I was only involved to check it was legit for others in the beginning, it wasnt for me to get involved for any prices, then JoJo told me it was going tits up & so I saw an issue & tried to help Simon by offering to supply the full service from door to door honestly, respectfully & honourably, for the life of me & other members over on that site we couldnt see the logic as he was getting stressed, missed his life & fedup which were his words to a degree, so why would you act in this manner, either he didnt wanna lose face as a mod or he had a vested interest, either way he has acted IMHO in a very bad way to make such a tbh fairly big cockup.
    But hey I tried to help the members over there & he wouldnt take it onboard & it was cheaper by some Ł15 or so, pass mate really have no clue as now everyone has ended up paying almost what I charge for 1 cable which is ridiculous for a GB of that size, its annoying for me as I feel its not the members interest the guy has at heart here, he was given other options to help save money & resolve it, he chose to stick with a high price, so again hows that in the members interest at all, afterall it was done for them & to cut costs.
    Anyway if there is a requirement for a GB then I would be happy to start one, just say the word boys.
    Quote Originally Posted by iyrix View Post
    Graham
    I sell the genuine Hex-Can-USB mate & trust me this is the one to have, plus the charges you see on RT's site are not the whole picure as you have 50 bucks for courier, then import/customs charges & it ends up costing more than UK, I can supply this, as have to numerous ASN members & others will contest to my service level, ask 1wheelonly as he's a customer, PM for further info.
  29. #28
    Oct 2009
    Hull
    1,434
    while we are on the subject of vag com and diagnostics etc etc i have seen THESE pop up from time to time!!!
    are they a waste of space?
  30. #29
    26,776
    They would do a certain number of things but its all down to the cars it can work on & the modules it has access to mate, thats why vagcom is better, much better, works on pretty much every VAG car old/new & is updated fairly regularly.
  31. #30
    Oct 2009
    Hull
    1,434
    will keep saving for a cable then!! :-)
    only another Ł241 quid to go lol
  32. #31
    26,776
    Get a loan, you'll never look back, lol
  33. #32
    Oct 2009
    Hull
    1,434
    i would love to but im paying enough out at the minute :-(
  34. #33
    iyrix's Avatar
    Mar 2010
    427
    lol
    Im going to get one, just need to wait for next payday!
    Cheers for all the advice people.
  35. #34
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,360
    You have an Audi, you need Vagcom,Simples !
    It will pay for itself the first time it diagnoses a fault correctly
  36. #35
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    Quote Originally Posted by Byzan A4 View Post
    couldnt agree more, everyone on here buys mods, ie: alloys, stereos, spoilers, bigger turbos, tints etc etc etc but when it comes to something that will save you money on your car and possibly make you some when helping others out, then people seem to go the cheap nasty route and then moan when it doesnt work or doesnt fill there expectations.
    they really do pay for themselves in time.
    iyrix, i would highly recommend NHN as a honest, reliable, trustworthy seller, many others on here would also vouch for him too.
  37. #36
    sebhar70's Avatar
    Apr 2009
    South London
    200
    As a matter of interest how many units would you need to sell as a group buy to offer the price you quoted on Briskoda Forum? If it's twenty or so I'm sure you could get that figure quite easily.
  38. #37
    26,776
    I would be happy to do a GB even for 20 people, save all some money mate, certainly can do it less than my current price & tbh less than the GB cockup over there & thats with 80% less buyers.
    Let me know or do you want me to start something up?
  39. #38
    Lancaster
    1,653
    I've just managed to get hold of a second hand one, well chuffed!
  40. #39
    26,776
    Just check registration details mate as if its been registered you may have to pay to change it to yours or dont do at all, you may not get support from RT if its in someone else's name.
  41. #40
    sebhar70's Avatar
    Apr 2009
    South London
    200
    Hi NHN,
    I want you to start one, put me down for the first order, I know about 20+ people pulled out of that GB and may be interested again for a similar price to what was originally quoted.
