Chris NottAH Fabrications
Results 1 to 9 of 9
Thread: LPG Conversion
    baynesey's Avatar
    well you better unsell them, sharpish!
    Mar 2007
    Stevenage, Herts
    194
    LPG Conversion
    Olla,
    Been thinking thrifty of late, and was thinking of possibly converting my A4 to LPG, I do approx 10k a year but seem to always be a petrol station has anyone converted thier 2.0 FSI to LPG, or can recommend a place that can do it?
    Cheers peeps
    2003 2.0 FSI SE A4 Avant
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,470
    You can get a quote and list of local LPG stations here http://www.greenfuel.org.uk/
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    baynesey's Avatar
    Mar 2007
    Stevenage, Herts
    194
    How Much Could I Save?
    Sorry, No Quote Available.
    The Greenfuel Company currently only converts single-point and multi-point injection engines.
    thats helpful LOL
    May 2006
    perth
    380
    I might be wrong but the single/multi point refers to the LPG system. I have a single point system fitted to my 3.9V8 discovery as it is a nice and simple engine. the gas is sucked in through the air intake and the injectors are turnd off. the Multi point is more complex as it injects the gas into each of the cylinders like fuel at the correct time. You would need the Multi point system.
    Contact http://www.tinleytech.co.uk/ they are very helpfull and i purchased my DIY kit from them. If you go down the DIY root (great instructions provided) you will need to get a certificate of safety from a specialist. this cost my 75. They may also fit kits or advice you of a local installer you could use.
    If anyone is intrested i have just spotted they do a Diesel kit!!
    notes taken from their website
    Diesel engines can be converted to run partly on LPG, partly on diesel. This method uses the combustion of the diesel to ignite the LPG. The benefits include large increases in power and reduction in emissions, particularly the black smoke often associated with diesels.
    Typically a ratio of 30% LPG to 70% diesel is possible. No adjustments are required to the diesel injection system and fuel savings come from the fact that throttle openings are lower due to the greatly increased power, which basically means you do not have to press the accelerator as hard to get the same performance.
    Fuel savings upwards of 30% are possible with the increased power levels seen as a major benefit to users.
    tiger727272's Avatar
    Oct 2007
    36
    I think the main thing for you will be how many miles will it take to pay for the lpg conversion from the cost savings achieved from lpg . If the figure is quite high then it might be easier and more cost effective to buy a diesel.
    However lpg vehicles do qualify for an exemption from the congestion charge in London, I dont know if this is relevant to you.
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    I know a guy through another forum who bought an A4 1.8T and promptly converted to lpg for 1,500+VAT. He does about 30k per year and the cost saving of buying a 1.8T compared to a similarly spec'd 1.9TDi paid for the conversion basically. Fuel economy is a little down compared to when running on normal petrol but comparing mpg on lpg compared to what a 1.9TDi can do gives a virtually identical running cost.
    Doing only 10k miles per year and say averaging 30mpg on petrol, using a bit of rough maths i'd estimate it would take you 2 years & 4 months to recoup the conversion cost. In other words unless your planning on keeping the car for a long time its not going to be worth it really!
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
    motorbikez's Avatar
    Nov 2006
    cumbria
    2,033
    Heres another word of warning as you will be well aware the government are scrabbling about looking to raise revenue in every direction.If a significant amount of motorists switch to LPG you can without doubt gaurantee the defunct labour government will raise the duty on LPG significantly making it a waste of your money to switch to gas.
    2007 Sportback S Line Tdi 170 Avus,Bose,Multi function steering wheel, Electric Lumbar support,Front centre armrest,
    Storage pack,Through load system,Folding mirrors,Non smoking pack
    2009 BMW K1300S, ABS, ASC,OBC, heated grips
    Sep 2007
    81
    Gotto agree with motorbikez, mate of mine used to run his old 4x4 on cooking oil and have you seen the price thats shot up to now because loads were doing it.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,470
    Quote Originally Posted by tjm69 View Post
    My neighbour runs his diesel on cooking oil (except for the week before his MOT!). Not only does it makes his engine noise really loud but you can smell the difference in his exhaust from all the other diesels in the road...
