Sky InsuranceJMB Retrofits
    Sep 2007
    Swindon Wilts
    170
    Problem with concert stereo
    hi,
    At low volume I tend not to have all speakers working! When i turn it up, they all come on! This is intermittent though.
    Didnt do it with another stereo I fitted. However I want to stick with the original and use a Xcarlink.
    COuld it be a dry solder? Anyone else had this?
    I initially thought it was the speaker door connectors but as its ok on another unit, it must be the unit itself.
    Any help appreciated
    Paul
    Jun 2003
    World of my own
    9,813
    Dirty connections on the door pillar connector is the most likely culprit. Do you have the Bose system, or just the normal one?
    The connectors are a pig to get to as they are hidden inside the inner skin of the A pillar up & under the dash at the sides. They get gunked up over time and turning up the volume overcomes the electrical resistance so you get speakers cutting out at low volume.
    Alex Turner
    Sep 2007
    Swindon Wilts
    170
    but it would do that on another stereo as well if it was that?!?
    Jun 2003
    World of my own
    9,813
    Do you have the Bose upgrade or just stock non Bose?
    Alex Turner
    Sep 2007
    Swindon Wilts
    170
    just stock I think
