does my keyfob need reprogramming if
baynesey
well you better unsell them, sharpish!
Stevenage, Herts
the battery died several months ago and hasnt been used since then, or can i just bang another battery in it'll work straight away?
ta
Chris
This is what it says in the owners manual.
After each changing of battery the system will have to be re-synchronised
if the vehicle is locked use the key to unlock it-
press the unlock button-
insert key into ignition and switch on ignition-
switch off and remove key-
press the unlock OR lock button.
did mine few weeks ago took seconds
