Results 1 to 9 of 9
    Feb 2008
    North West, UK
    141
    Electric Window Problem
    Hi,
    Last night I was "showing off" to my father in law how when you keep hold of the unlock button on the remote that the windows all open (I only found out about this last week ) but the rear drivers side window was very slow at closing and got 2/3rd's the way up and went back down. I couldnt fully close the window at all, then I managed to get it nearly to the top but it seemed to be at a slant with a gap of about an inch to the top. Ive managed to push the window up physically but Im not sure what could be causing this.
    Is it likely to be the motor that is dying or has the glass come loose from the frame?
    thanks.
    54 A4 Avant 1.9TDi SE 130 6sp, factory fitted RNS-E Sat Nav, Colour DIS, 6-disk changer, Bluetooth, rear parking sensors and ambient lighting.
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    Sods law something goes wrong soon after the warranty runs out!! Out of curiosity why were you showing off that the windows went up & down with the remote?! Did your father-in-law not believe you when you just told him?!
    Anyway, if the window isnt straight anymore its probably hanging off the carrier or popped out of the front or rear guides. If your handy with a screwdriver take your door panel off and take a look. Whatever you do dont try & operate the window until its looked at in case something gets really broken that costs mega bucks!!
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
    spacey's Avatar
    A4 Avant - 163 1.8t
    Feb 2008
    Newcastle
    15
    do a4's generally have the same problems as vw with the window regulators?
    Feb 2008
    North West, UK
    141
    Well without wanting to sound "snobby", he's one of those "mine is better than yours" types although he does laugh about it, but anyway he drives a Ford Fiesta Zetec and just joking when we were leaving I said to him "I bet yours cant do this".................... "my window not work? yes your correct!"
    A proper egg on face moment that was! lol
    I'll take the panel off tonight (weather permitting) and have a look. Is the panel relatively easy to get off? like just a few screws?
    And yes, just out of warranty too
    Jun 2007
    Hampshire
    846
    Quote Originally Posted by Slinger
    Yes, all the screws are pretty obvious bar at the front edge, but just look hard and you shall find! It lifts upwards by the way so dont try & pull it straight off else you'll break something else!!
    Jun 2003
    World of my own
    9,813
    You may want to pop down to the dealer first and buy some of the fasteners that hold the panel on, as these are designed to break when you remove the panel. You need to pop the panel out before lifting it up. This is the front door but the rear are identical IIRC:
    Alex Turner
    Jun 2003
    World of my own
    9,813
    This is what you'll reveal, so don't know how much you can access once you remove the foam:
    Alex Turner
    Feb 2008
    North West, UK
    141
    Thanks for the help guys, thats great I'll obviously have to remove the aluminium trim / strip from the door panel to access those screws. Is that just a case of pulling off?
    Jun 2003
    World of my own
    9,813
    Prise it off at the narrow end first as it's hinged at the end near the door hinges.
    Alex Turner
