Results 1 to 16 of 16
Thread: 1.8T engine
    Jan 2005
    62
    1.8T engine
    I currently have a mk4 golf GT TDI remapped 160bhp and 280lb-ft torque.
    I am looking to get a 1.8T 190bhp A4, if i do would i miss my Golf? Even though the Audi has more BHP it has much less torque. Even a remapped A4 only has around 220lb-ft torque.
    Or is the power band in the Audi alot better that it wont miss it?
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    A remapped 190 A4 should have about 230-235lbft of torque.
    My car peaks at 270ish and is flat from 2500-5000 @ 250lbft.
    The power is linear unlike the whooosh-it's over delivery of a TDi.
    I doubt they'll be much between the two on tight back road blasting but the A4 will leave the Golf once given the chance to stretch its legs.
    BUB
    A4 Avant S-Line quattro - Avus Silver/Silver Half Leather *240ps*346nm* - a few choice mods. Now Stared up ;-)
    Jan 2005
    62
    Wow, whats mods are you running to achive that high amount of torque? Is it just a remap?
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    # K&N Panel filter
    # Hyperboost HX diverter valve
    # Oettinger Alloy Intake pipe
    # Milltek cat' back system
    # Star Performance special remap
    Better economy now too
    I gave it an oil change, fitted a set of spark plugs and serviced the DV last weekend and swear it's got another 5bhp and 10lbft!!!
    BUB
    Jan 2005
    62
    If i can achive those figures, i will defiently not miss my Golf TDI.
    Whats a Hyperboost HX diverter valve? is the Oettinger pipe from airbox to turbo?
    Lastly did the exhaust give it any more and whats special about the remap?
    thanks mate
    pav-g's Avatar
    Jan 2007
    Bradford
    728
    Impressive results Bub - by the way where did you get K&N air filter from.. I suppose that on its own should make some difference i.e. better airflow
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    I can't remember now, some small mail order place a good while back. I doubt the filter would make any real difference but as Tesco say.................
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    Quote Originally Posted by A8UK
    thanks mate
    Hyperboost
    Yes, pipe is airbox to turbo..............
    You can get silicone ones now from Samco etc. Worth 5 odd bhp, smooth power and stop surging from intake hose collapse.
    I wasn't expecting much from the exhaust, I just wanted to add a bit of character really. But it really did help make the engine smoother low down and give a lovely midrange surge - recommended
    The map is running just a bit more boost than Stars normal 190 remap. Just ask Jim for it It's been nearly 3 years and it hasn't missed a beat.
    Jan 2005
    62
    Thumbs up
    Thanks for all the help mate,
    I think ill go with the samco hose instead as its alot cheaper than the oettinger version.
    I was thinking of getting a k04 turbo before i get it mapped. They can be bought quite cheap off ebay. Do you think i would benefit enough from it or will the k03s be ok?
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    Don't bother with the K04.
    The turbo fitted to the 190ps is as good as a K04-015.
    Just take a look at what the Yanks are getting from K04's on Audizine etc. I'm getting the same sort of numbers (sometimes better).
    The next step for me would be a front mount intercooler and real big turbo............
    BUB :dream:
    Jan 2005
    62
    Im hoping to change to a big turbo in the future too. I was looking at the GTRS turbo.
    i was told that with some bigger injectors along with the turbo i can expect 300bhp. What do you think?
    Jan 2005
    62
    Also what sort of performance figures does your car give??
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Im in the process off looking into my Turbo Upgrade to, Been on to Backdraft, Awesome, some place in Scotland, another place in London...its driving me nuts, there is sooo much varient in Prices for more or less the same power but the cheaper quotes are coming from the less well known companies!!
    Im looking at around 5500 for 325-335Bhp :
    GT2860RS -5005S ball bearing turbo 0.64 AR
    Hi Flow cast manifold
    3 SS downpipe and sports cat
    3 SS Inlet pipe
    SS Charge pipe
    Forge custom Front Mounted Intercooler
    Silicone connecting hoses (Blue, Red or Yellow)
    Braided oil and water hoses
    SS oil drain bottom pipe.
    Gaskets
    Hose clamps
    Actuator bracket and SS extension rod
    Studs, Bolts, Nuts and washers
    Genesis 550cc Injectors
    Bosch 4 bar fuel pressure regulator
    ...but could chop that price down by over 1.3k if I can trust the fitter I have in mind!
    Jan 2005
    62
    I was told by ATP that just a GTRS turbo will give around 280bhp.
    a 190 has twin intercoolers and bigger injectors so a front mount or bigger injectors are not needed unless you are going for over 300 bhp.
    Stock manifold is suppose to be quite good and i will be running the standard exhaust for a while.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    ...thats the package for my Spec as I dont run a 190bhp model, mines the 163 edition - 150 if you wanna say!
    Im running 205ish at the min and have the one intercooler hence the reason for the front mounted.
    Your tuning would be alot cheaper than the package I require.
    Jan 2005
    62
    Oh, do you know if the 190 engine has different internals to a 163? Is the 190 any stronger? Why are you going for a GT2860RS compared to a GTRS or GT2X?
    Also what sort performance figures can you expect froma big turbo?
