AH FabricationsEM Tuning
Results 1 to 13 of 13
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    Cruise Control part numbers
    After finally deciding to keep my car and put up with the expensive fuel bills im going to start doing the mods i've put off. 1st up im going to tackle cruise control! I've searched and got plenty of instructions on how to actually do the mod but cant find a definative list of the part numbers needed. Its an '02 B6 saloon so it seems I need:
    1 x replacement steering wheel control module
    1 x cruise control stalk
    1 x replacement steering column cowling
    Can anyone provide me a part numbers list for these items?
    Cheers,
    Nick.
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
    Nov 2006
    liverpool
    703
    do a search mate- im sure 'neil s' has done this mod and he posted all the part numbers on there aswell
    Jun 2007
    Hampshire
    846
    Quote Originally Posted by chris_20
    Done a search and couldnt find any part numbers for the A4 B6, loads over on the A3 forum though!! I remember Neil S's post a few weeks back on this, i'll PM him I think
    Sep 2007
    Swindon Wilts
    170
    has anyone done this on an oil burner (52 reg 1.9TDi)?
    I would be interested in doing this. What sort of costs are involved for diesels? Also is it affected by remaps?
    thanks
    Paul
    Neil_S's Avatar
    Jan 2006
    Hampshire, UK
    248
    For the record...
    1 x 8E0 953 549 N Steering wheel control module
    1 x 8E0 953 521 D Cruise control stork
    1 x 8E0 953 512 L Colour Code: 3ZQ - Lower trim part Martitime blue
    2 x N 909 068 01 M2 screws
    Colour code will differ for the new lower trim part.
    You will also need
    1 x T55 socket bit
    1 x T15 screwdriver
    1 x T8 screwdriver with 60mm reach. These are suitable from Maplin, just trim the plastic so it fits in the hole to take off the lower trim...
    15 piece precision screwdriver set from Maplin (code: N25CX) for a fiver (it has a 50mm shaft) and trimmed 10mm of the plastic off the end of the shaft to give me 60mm length with which to fit in the hole...
    http://www.maplin.co.uk/Module.aspx?...N25CX&doy=21m2
    Neil_S's Avatar
    Jan 2006
    Hampshire, UK
    248
    For vag-com instructions see the fifth post by Shark_90...
    http://www.tyresmoke.net/ubbthreads/.../Number/823305
    I followed them apart from instructions for module 17
    Neil_S's Avatar
    Jan 2006
    Hampshire, UK
    248
    Quote Originally Posted by bonerp
    thanks
    Paul
    Costs about 110 for the module and about 50 for the lower cowl, stork and screws.
    Vag-com license required for part of the enablement process, about 50 for that, plus a shareware cable from ebay for about 15.
    It shouldn't be affected by remaps or anything.
    Sep 2007
    Swindon Wilts
    170
    hmm sounds a bit technical. Dont even have vagcom. I'll see what the stealer will charge!!!
    Nov 2006
    liverpool
    703
    Id hate to think how much the dealer would charge!
    Niknak's Avatar
    Oct 2006
    manchester
    864
    I was recently quoted £398! by Stafford Audi
    Jun 2007
    Hampshire
    846
    What a result, whilst pricing up the bits for my cruise control retrofit i've discovered I already have fitted the correct steering wheel control module thus saving myself the 85. Cruise control for 41, bargain!!!!! Now, should I spend the money i've saved on some xenons or alu mirrors???
    May 2006
    perth
    380
    is the cruse stalk for the 2002 models a replacement indicator stalk with cruise buttons or a seperate stalk altogether?
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,533
    Quote Originally Posted by samuelt
    It's a separate stalk just below the indicator stalk.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
