Badger5EM Tuning
Results 1 to 7 of 7
    Oct 2007
    54
    Spray on Avant rear window ?
    Hi all,
    Just wanted to check if all avant owners have the same experience and if there is any way to curb the problem. My avant rear window gets hellishly dirty with even the slightest moisture on the road! I was wondering is this normal, and whether an S-line style rear eyebrow spoiler would help or even rear mudflaps?
    Any advice would be much appreciated!
    Scottyjohn
    www.flashsync.co.uk
    2002 A4 Avant TDI 130 SE
    Feb 2008
    North West, UK
    141
    Yup, suffer the same problem myself, I think its par for the course with estate cars.
    54 A4 Avant 1.9TDi SE 130 6sp, factory fitted RNS-E Sat Nav, Colour DIS, 6-disk changer, Bluetooth, rear parking sensors and ambient lighting.
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    Its an aerodynamic trait of pretty much any car without a boot behind the window, ie estates and hatchbacks. Its caused by the turbulence as the air passing over the roof meets a void underneath suddenly where the pressure is lower. The air is then sucked in from all angles bringing with it all the rain & road muck with it and it gets splattered on the rear of the car. Only thing you can do is drive really slow to reduce the pressure drop behind the car sucking in the rain & muck!! By the way, this is pretty much the reason they dont fit rear wipers to saloon cars as they generally dont suffer from this problem.
    God i bore myself sometimes with the crap I know!!
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    There's only one way I've found to fix it on a hatchback or an estate - fit an additional spoiler below the rear window.
    Did this (many years ago) on a Metro, and hardly needed to use the rear wiper afterwards.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Mar 2003
    153
    We have mudguards on our B6 and it still kicks up the dirt. I've always had either hatchbacks or estates though so I'm used to it.
    Don't you invalidate the warranty on a german car by looking behind you? :-)
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Quote Originally Posted by SimonP
    Only if it's got three letters and a round badge with blue and white segments!!!
    And they also come without indicators...
    Mar 2003
    153
    Quote Originally Posted by PetrolDave
    No, they definitely come with mirrors, as when you approach them they are dawdling along following the line of traffic until you make the first move to overtake, at which point they pull out and go all psychotic - all without signalling of course :-)
